Archived from groups: microsoft.public.windows.networking.wireless (
More info?)
You are right. I did not see that the OP mentioned that the modem was USB.
This implies that it has to be connected to the PC which means that the PC
probably has to be on all of the time. I would suggest getting a modem that
has an ethernet plug for the home side. This would allow greater
flexibility in choosing a router.
Jeff
"Jack" <
www.ezlan.net> wrote in message
news:%23Jt2ELTnEHA.2552@TK2MSFTNGP11.phx.gbl...
>I do not think that FVS318 works with USB Modem.
> Actually almost all of the Entry Level Cable/DSL Routers do not work with
> USB Modem,
> "liamski" <liamski@discussions.microsoft.com> wrote in message
> news:6968BA78-B5D5-4D68-8ADD-18544043DAF7@microsoft.com...
>> Thanks Jeff - this is great advice and much appreciated
>> Lee in London
>> "Jeff Durham" wrote:
>> > Here are my comments:
>> > - Does your provider allow you to resell their connectivity?
>> > - To limit bandwidth, you are going to most likely have to invest in
> more
>> > expensive router equipment
>> > - Otherwise, I would recommend using something like a Netgear FVS318
> router
>> > with firewall along with a wireless access point such as a Linksys
> WAP54G.
>> > I only mention these as I have used them. Take a look at comparable
>> > equipment from other vendors.
>> > - I believe that separating the router from the access point gives you
> more
>> > flexibility and less problems, but it will cost you a few dollars more.
>> > - By using a router to hand out DHCP addresses, your PC does not have
>> > to
> be
>> > involved. You can leave it turned off and everyone else will have
> access.
>> > - As for security, I would not do anything less than WPA Pre-shared
>> > key.
>> > WEP is okay, but with WPA being widely available in new equipment, you
>> > should stick with it. Even better, if you setup a Win2k or Win2003
> server,
>> > you can go to WPA RADIUS using EAP-TLS and certificates. That is much
> more
>> > complicated than you probably want to get into.
>> > - Skip the MAC address filtering and hiding the SSID. That causes more
>> > problems than it is worth. If you are concerned about neighbors giving
> out
>> > the shared key associated with WPA-PSK, you can turn on MAC address
>> > filtering. However, any decent hacker can quickly spoof a MAC address.
>> > Hiding the SSID only causes problems with Windows XP.
>> > - As for connectivity through walls, you will just have to try it and
> see
>> > how it works.
>> > - Keep in mind that you are in for a support nightmare by doing this.
> If
>> > someone is playing online games at 2am and their wireless connectivity
>> > suddenly goes down, they have every right to come banging on your door.
>> > Jeff
>> > news:43828ABF-7F94-46E5-B364-D8D30012429A@microsoft.com...
>> > > Hi there
>> > > I'm a complete newbie at Wireless networks so please be gentle with
> me!
>> > > In short, currently I have a PC, a USB ADSL modem and a fat new
> 4.6megabit
>> > > ADSL connection.
>> > > I'm looking to 'sell' my spare capacity to my neighbours who live in
> my
>> > > apartment block. I would like to keep 2megabits for myself and let my
>> > > potential customers share the other 2.6mbits.
>> > > The block itself is (a) 3 storeys high, (b) timber framed and (c) I
> live
>> > > on
>> > > the ground floor.
>> > > From a technical point of view, I'm not sure if my idea is possible,
> and
>> > > what hardware is required if it is. My questions are..
>> > > 1) What hardware/software would i need? I'm assuming I need a router
> of
>> > > some
>> > > sort.
>> > > 2) Would the signal from the router be strong enough to penetrate
>> > > 30ft
>> > > with
>> > > 2 ceilings in between (if you see what I mean)?
>> > > 3) How can I make it secure? MAC addresses?
>> > > 4) How can I throttle the bandwidth I give to them?
>> > > 5) I don't want to have to leave my PC on all day. Is there a setup
> that
>> > > doesn't need that?
>> > > Any help would be appreciated - I'm reasonably technical but not
> enough
>> > > though!
>> > > cheers, L
