Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Help: Hi-8 to digital via capture card
Archived from groups: rec.video.desktop (More info?)
I have a Sony TRV-318 Hi-8 camcorder. I am attempting to hook it up
through a Sondmax Digital Audio card. I've used the S-Video connection
for the video portion and it has worked fine, The problem is, I can't
get the audio to work. I'm using a Winfast pvr and the sound works
fine for the TV tuner, etc. I've tried to hook up the AV out to the
audio in on the Sound card, with no luck. If anyone has a trv-318 and
is familiar with the problem, I need some help. Thanks.
jm
Sponsored Links
>jm
Just a thought: You are aware that the SVideo connector carries video ONLY, no
audio? That to get audio out of the camcorder you need the "AV Cable" that has
a 3.5mm 4-or-5 ring plug on one end and white, yellow, and red RCA connectors
on the other. Video is (usually) yellow, left audio is white, and right audio
is red.
Reply to Anonymous
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
