Archived from groups: microsoft.public.windows.networking.wireless (
More info?)
I put a Cisco 340 wireless card into the PC Card slot, brought it up on my
WIFI/WEP network, and then switched from AC to battery and back. No network
problems like with the embedded card, which is a Cisco 350. So - is it
hardware or not? Because it fails when managed by Windows and works when
managed by the Cisco configuration utility - its hard to say. I'll try to
swap disks with a similar computer and see if the problem follows the disk.
Thanks for your ideas on this Brian. We now at least have another hint to
this obscure problem.
"Brian Wehrle [MSFT]" wrote:
> Since IBM has not heard of this, and neither have I, it might be safe to
> assume that there is some hardware problem and the card is behaving
> different in a low-power situation. The Repair functionality, as a last
> resort, stops and re-starts the network card driver, so it basically resets
> the hardware completely. I'm glad to hear that this at least fixes the
> problem. However, this is not the behaviour we want from our wireless,
> mobile laptops! I will ask a colleague if this problem has been reported
> before with Wifi hardware, though I suspect not.
> I would like to propose a test, but it would require using a different
> network card. If you could borrow a PCMCIA card from a colleague and do the
> same test it would be of great interest. Could this be done?
> Brian
> Brian Wehrle
> bwehrle@online.microsoft.com
> Software Test Engineer/Wireless Networking
> Microsoft Corp.
> "skibum442" <skibum442@discussions.microsoft.com> wrote in message
> news:A0BD6A1A-9002-4AD3-A675-E35955A6170D@microsoft.com...
> > Thanks for the reply. On your advice, I tried setting the wireless card
> > to
> > max power save (and the other two options as well), and saw no change to
> > the
> > symptoms. Also tried disabling power management in the control panel's
> > power
> > setting. When I switch AC to Battery, the screen flashes black for a
> > millisecond and ends up dimmer than under full power. I have not found
> > any
> > control for that - to disable its routine - just in case that might fix
> > it.
> > "Robban" wrote:
> >> Hi,
> >> I have seen a similar case in this NG not that long ago. My
> >> recommendation
> >> was to check the power saving settings.
> >> There was nothing wrong with the standard Windows power settings, but the
> >> problem was solved by changing the power saving settings for the WLAN
> >> card
> >> to Maximum.
> >> br/rob
> >> news:1AC47E95-5DD1-4AB6-ADBA-52F4BD44178D@microsoft.com...
> >> > IBM Thinkpad T41 with embedded Cisco card. All the latest drivers,
> >> > bios,
> >> > etc. IP address on wireless is lost when switching from battery to AC
> >> > or
> >> AC
> >> > to battery. Scenario: wireless working great, excellent signal. Pull
> >> > out
> >> > power cord. Within about a minute, connections fail, and IP address
> >> > 169.254.200.115 is assigned to wireless connection. Signal is still
> >> strong,
> >> > but error message comes up saying "limited or no connectivity...".
> >> > When I
> >> do
> >> > a repair, the connection comes right back with a valid address and
> >> wireless
> >> > works great again. Chatted with Microsoft XP2 support and IBM
> >> > technical
> >> > support. Nobody has ever heard of this before. Well, now you have!
> >> > Other details:
> >> > Using windows to configure my wireless networking
> >> > WEP Open authentication
> >> > Connect when this network is in range "enabled".
> >> > Symptoms the same if firewall is on or off.
> >> > My thoughts - something in the power event within the OS (or IBM's
> >> > power
> >> > management code) is killing the IP address - perhaps its going through
> >> > a
> >> > "should I suspend" logic and that is where the problem is. When the
> >> > new
> >> > power scheme is settled down (screen brightness lowered, etc), it does
> >> > not
> >> do
> >> > a DHCP request to regain its lost IP address.
> >> > Looking forward to your comments and suggestions.
