Tom's Hardware > Forum > Games General > Games General Discussions > HL2 and GeForce4 Ti4200 = Problem
Forum Games General : Games General Discussions - HL2 and GeForce4 Ti4200 = Problem
Archived from groups: alt.games.half-life (More info?)
Help.
I can't even start Half-Life 2.
First I try to start the game in standard mode, then in secure mode, but it
is impossible.
Get the message "Failed to set video mode. This game has a minimum
requirement of DirectX 7.0 compatible hardware." I have installed the
newest drivers for the videocard.
Can I make this work, or do I need a new videocard?
SYSTEM SPECS:
MB: Nf7-s V2
CPU: Barton XP2500
RAM: 512MB PC 2700
VIDEO: GeForce Ti 4200 128MB
OS: XP Pro w/SP2 - up to date
DirectX 9.0c
Sponsored Links
Recommend using 45.23 drivers for the card - that is what I use for HL2
and my Ti4200. Works fine, min 30fps, typically 60fps.
Although I will probably get flamed for suggesting using an older
driver.
It works just great for me with all my games, and I do buy newer games.
Reply to Anonymous
I was strolling through alt.games.half-life one day, when suddenly
Ruben Eidesen surprised me by leaping from a nearby hedge.
As I levelled my service revolver, the unfortunate creature cried out;
I wouldn't have thought you'd need a new video card - I'm using a Ti-
4400 myself (not too far away from your card in terms of spec) and it's
fine. As the others have said, a different driver could be the key.
If it helps, I'm using 71.89 on mine, from nVidia not the hardware
vendor (I'm XP SP2 as well).
Are nVidia drivers still finicky about having old driver versions
around..?
WildStyle24_7
"The same beat produces the same evil inclination
EVEN if we tie the words Jesus Saves to it;
let's build a bonfire and get rid of this TRASH."
-Fundamentalist Preacher on the dangers of Rock 'n' Roll
Reply to Anonymous
It works!
Used driver 71.84.
Got a message that said that this was an old driver and that I should
upgrade to a newer one.
Ignored that message, and then the game started loading :-)
Thanx A lot!
Regards,
Ruben
"WildStyle24_7" <wildstyle247@gmail.com> wrote in message
news:MPG.1d3771a874f285a698aa98@news.individual.net...
> around..?
> WildStyle24_7
Reply to Anonymous
> driver.
Not at all - I run HL2 and all my other games just fine with ATI
catalyst drivers from october 2003 :-) (cat 3.10) .. as far as i see
it, i've never had a problem, so why fix sommat wot aint broke ;-)
ditto :)
Ben Cottrell AKA Bench
Reply to Anonymous
"Ben Cottrell" <bench@bench333.screaming.net> wrote in message
news:3j5uhhFoenggU1@individual.net
>> HL2 and my Ti4200. Works fine, min 30fps, typically 60fps.
>> driver.
>> games.
> ditto :)
Nice to see ya pop in again Ben! Glad you aren't a casualty of
yesterday :\
McG.
Reply to Anonymous
- 0 +
>> driver.
Says me who switched drivers 3 times this week, "If it ain't broke, your
not trying hard enough."
I managed to get my HL2 and CS:S to only work in a 640x480 windowed
screen with new drivers. Hard to play CS:S that way.
> ditto :)
Jethro[AGHL] aka Phat_Pinger
Reply Email: jethro86 (at) gmail (dot) com
Reply to jethro
There are 1045 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
