Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > How do I connect wireless to wired home network?
Forum Wireless Networking : Wireless General Discussions - How do I connect wireless to wired home network?
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have 4 computers on home network wired to a D-Link 4-port router. I
bought a D-Link wireless router which I want to connect to the wired
network so that I can use a laptop around the house. I have assigned
192.168.0.1 to one computer on my home network which is the gateway
computer for a dialup Internet connection (I use ICS as well, and yes it
is slow when a couple of people are surfing). All other computers have
various IP addresses.
The wireless router and the wireless card are "b" format.
The wireless router is likely a default IP of 192.168.0.1, so I would
have to change it to something different than the other computers on the
network, I think. Can I use the wireless router as an access point?
Otherwise how do I set up my network?
BTW, I know pretty much squat about this stuff so please make it simple.
Ron
Sponsored Links
You will not need both routers. Replace the wired router with the wireless
one, assuming that it includes wired ports as well as antennas.
Reply to papa
- 0 +
Well, I want to. That was the point of the post.
Ron
Reply to at
- 0 +
OK, then remove the old router, connect up the new router, and run the
install program that should have been supplied with your new router. It's a
piece of cake.
"at" <"joiner(at)ns.sympatico.ca"> wrote in message
news:u77BXcboEHA.3396@tk2msftngp13.phx.gbl...
>> wireless one, assuming that it includes wired ports as well as antennas.
> Ron
Reply to papa
- 0 +
Hi
That is the way to do it: Wireless Router as an AP:
http://www.ezlan.net/router_AP.html
What might be the Adavdage?
You can put the Wireless Router in a better location for good Wireless
Distance.
Jack (MVP-Networking).
"Papa" <bikingis@my.fun> wrote in message
news:urwRTKdoEHA.3988@tk2msftngp13.phx.gbl...
a
> piece of cake.
antennas.
> > Ron
Reply to Jack
- 0 +
Jack wrote:
> Hi
> Distance.
> a
>>piece of cake.
> antennas.
>>>Ron
Thanks
Reply to at
I have the same problem -- 4 computers on a LAN using a wireless Linksys G
Broadband router.
I can access the Internet through the router, but I can't see the Workgroup
at all. Just a blank screen.
The computers on the LAN can see the laptop's icon but can not access it
(even though I've shared the whole C drive).
I figure the router must be ok cause I can get though to the Net, so it must
be something that in my setup on the laptop.
When I setup the router I named the group "office", whereas the Workgroup is
"horizon". I tried making it the same name, but that didn't work. (One was
capitalized and one was little letters)
Surely there is a way to access both the Internet and the Workgroup.
Any suggestions?
> piece of cake.
> > Ron
Reply to Anonymous
On the assumption you have set each machine up using the 'Wizard' and
enabled 'file and printer sharing' the likely problem is your firewall
settings. To confirm this disable the firewall on each machine and then see
if you can see the machines.
"Can't get both LAN and Internet" <Can't get both LAN and
Internet@discussions.microsoft.com> wrote in message
news:DC1C50A0-B680-4B35-A52C-411F059EB725@microsoft.com...
> Broadband router.
> Workgroup
> must
> is
> was
> Any suggestions?
>> a
>> piece of cake.
>> >> antennas.
>> > Ron
Reply to Anonymous
- 0 +
All work group names for every computer in the LAN must be EXACTLY the same.
> Broadband router.
> Workgroup
> must
> is
> was
> Any suggestions?
>> a
>> piece of cake.
>> >> antennas.
>> > Ron
Reply to papa
There are 1132 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
