Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Q: Need cable from Nikon Coolpix 4500 ouput to frame-grabb..
Forum Computer Peripherals : Digital Cameras - Q: Need cable from Nikon Coolpix 4500 ouput to frame-grabb..
Archived from groups: alt.comp.periphs.dcameras (More info?)
Hi,
Our research group is going to be purcahsing a Nikon Coolpix 4500 for use with a microscope for taking video of biological samples. We would
like to stream the data to a computer with a frame grabber. The board we were thinking of is the Nat'l Instruments PCI-1407 which has BNC
inputs only.
Does anyone know of an apprpriate cable that would connect the video ouput of the Coolpix to a BNC input?
TIA,
-Mark
Sponsored Links
Why don't you just take pictures in the camera and get much more resolution?
"Cueball" <bray@REMOVE.vanderbilt.edu> wrote in message
news:doa6s0t6m2tinegjvqs65r8kt0kqbviak7@4ax.com...
> Hi,
> inputs only.
> TIA,
> -Mark
Reply to Anonymous
> resolution?
Usually you want to use the video for realtime frame and focus on the PC
screen before you take the full rez image.
>> Hi,
>> for use
>> board we
>> inputs only.
>> ouput of the Coolpix to a BNC input? TIA,
>> -Mark
My guess is you'll need to decode the composite video signal and split out
the sync, and in general this involves a decoder box. Check out the
application notes for your device at www.ni.com.
If you are not using currently existing software that requires this device,
consider using other hardware. There is a mass market of inexpensive PCI
capture boards that work directly with a variety of formats of composite
video, and are easily programmed via the standard Windows DirectX api, so
your project is not joined at the hip to a particular piece of hardware.
Mike Russell
www.curvemeister.com
www.geigy.2y.net
Reply to Anonymous
The only video I have seen come off these cams is 320 x 160. Not really
worth even focusing with.
"Mike Russell" <REgeigyMOVE@pacbellTHIS.net> wrote in message
news:dtSwd.645$wZ2.35@newssvr13.news.prodigy.com...
> > resolution?
> >> Hi,
> >> for use
> >> board we
> >> inputs only.
> >> -Mark
device,
> Mike Russell
> www.geigy.2y.net
Reply to Anonymous
Mike is right. I only need a preview image.
Any ideas on the original cabling question?
-Mark
>> > resolution?
>> >> Hi,
>> >> for use
>> >> board we
>> >> inputs only.
>> >> -Mark
>device,
>> Mike Russell
>> www.geigy.2y.net
Reply to Anonymous
> -Mark
You'll need not just a cable but a composite video synch splitter box to
separate the synch and video. More than likely you have four BNC cables -
synch and one each for RGB. If there is only one BNC input to the NI
capture board, you may only need an RCA female to BNC male adapter from
Radio Shack.
Consider abandoning the NI board if you have a choice in the matter, and get
a consumer PCI video capture board probably for less than the splitter would
cost
Mike Russell
www.geigy.2y.net
Reply to Anonymous
On Mon, 20 Dec 2004 15:34:37 GMT, "Mike Russell" <REgeigyMOVE@pacbellTHIS.net> wrote:
>> -Mark
>Radio Shack.
You're right; there's only one BNC input, that takes NTSC, PAL, or VGA input. The camera puts out NTSC and PAL. I assume the one cable
should be acceptable for this...?
>cost
We're no too hoprribly worried about the cost. The reason we were going with the NI product is that we were hoping to create a LabView VI to
integrate with some of our existing software.
-Mark
Reply to Anonymous
Then all you need is a plug adapter from Radio Shack, or get an RCA
male-female and solder a male BNC on the appropriate end and you're set. Or
in a pinch marry an old scope probe cable and an RCA cable.
> VI to integrate with some of our existing software. -Mark
LabView is pretty convenient. Good luck. It looks like you're just about
there.
Mike Russell
www.geigy.2y.net
Reply to Anonymous
There are 1070 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
