Archived from groups: rec.video.desktop (More info?)
Not trivial.
First you will have to rip the DVD to your hard drive
(using SMARTRIPPER or something similar).
Then use a tool like VOBRATOR to extract the video
and all audio tracks.
Then use a tool like AZIDLAME to remix the DD 5.1
audio to 2 channel mp3 files.
Then use a tool like TMPGENC to join the *.mpv video
stream and the *.mp3 audio stream together to generate
a valid *.mpg MPEG-2 file (go to FILE->MPEG-Tools -
no recompression necessary for this step!).
Finally you can easily include this *.mpg file in your video
project.
Good luck.
Martin
"SR" <srannou@wanadoo.fr> schrieb im Newsbeitrag
news:fdq0d0las1vvjc5evdb0ie4ngi4bq2is83@4ax.com...
> How to insert with Studio 8 a short extract from a DVD into a home
> made vide
> I am working with a PC
> TIA
> Serge
On Wed, 16 Jun 2004 21:13:00 +0200, "Martin Doppelbauer"
<Martin.Doppelbauer@t-online.de> wrote:
>Not trivial.
>project.
>Good luck.
>Martin
>> made vide
>> TIA
>> Serge
