Archived from groups: rec.video.desktop (
More info?)
"Keith Clark" wrote:
> Jon Danniken wrote:
> > Howdy,
> > I have been playing around with VirtualVCR for the last couple of days, using it to capture CableTV
(NTSC)
> > to a divx AVI format. Once captured, I convert to VCD or SVCD after cleaning up the audio a bit.
> > I am interested to know what bitrates those of you doing a similar thing are using for capture. I
have
> > been using divx settings of "Standard" at "2400 Kbps" with audio set to PCM uncompressed. These
settings
> > will allow me to record an hour and change before the resulting file runs into the two gigabyte limit.
> > My main question here is, do these settings seem typical for what you would use?
> > Any suggestions or insight appreciated,
> > Jon
> First, I'd stay away from out-dated VCD and SVCD formats.
> When doing DivX or Xvid, consider storing the audio at 128 or 256 kb/s MP3 audio. This will save a lot
of
> space and any player than can handle DivX will handle the audio fine.
> You can also save a lot of space by doing a 2:1 reduction (give a 352x240 size which will scale
perfectly to
> full frame on playback). After I edited out the commercials, one movie I recorded from cable fit on a
CD. Of
> course it didn't look as good as the original 7 GB mpeg-2 file but it was good enough and better than
anything
> on a tape considering playback was on a TV rather than a PC monitor.
> Lastly, you need to upgrade your OS to one that can handle NTFS and you won't have file size issues. I
don't
> know about Germany, but here you can get XP Pro "OEM Edition" from many mom & pop computer stores for
less
> than $150 (I bought a copy yesterday for $146 plus $3 for a mouse to qualify as "hardware" required by
MS to
> be sold with the OS), that's a lot less than buying the boxed edition...
Thanks for your response, Keith. The main reason (for the time being, at least) I am finalizing with
VCD/SVCD is to take the occasional show to a friend's house. In any case, though, while I am using DivX
for the video encoding, I can't seem to get any of my capture applications (VVCR, VDub, others) to encode
to MP3 "on the fly" during capture (post-production works fine to encode the audio in MP3).. I tried the
LameACM and even the Fraunhofer/Radium thing, but regardless of MP3 codec I choose it crashes the capture
app (I'm still looking in to why this is occuring)..
I am using a WinTV (Hauppauge card), capturing NTSC at 320x240 right now, and am using Win2000 with NTFS;
the two gigabyte limit is for AVI (isn't there a two-gigabyte limit on AVI?).
My main question, though, concerns how much video compression I can get away with on the original capture
without a great impact on quality. I do know that the incoming broadcast isn't very high quality, but how
much more bandwidth I should allow for compression is what I am trying to figure out. In other words,
what bitrate will give me the best practical quality for capturing cable television, without going _too_
far into the law of diminishing returns.
I know it is a subjective opinion, and everyone will have their own settings, but I'm just looking for
some feedback as to what others are using when doing a similar activity, i.e., capturing cable-tv with
Divx compression.
Jon
