WPA hotfix problem
Forum Wireless Networking : Wireless General Discussions - WPA hotfix problem
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Got a desktop running XP SP2 and a laptop running XP SP1. Not keen to
possibly mess up my wireless network (3com router, 3com wireless card in the
laptop, wired link from router to the desktop) so I don't fancy installing
SP2 on the laptop just yet. However as I understand it, SP2 or a hotfix is
needed in order to take advantage of WPA (this I assume because that's the
impression I get from reading about it and there is currently no option to
use WPA in either windows wireless config or my hardware manufacturers
config software on my laptop. The desktop however has the option to use it
in the router config software - and the wireless card definitely supports
it).
So I installed a windows hotfix on the lappy which apparently adds WPA
support in SP1. However - after installing said hotfix, the laptop runs
slow, programs hardly ever open and as for connecting to the net via the
wireless card - forget it. Had to uninstall to get my system back. Uninstall
it and all is well - runs fine, connects, browses, network, internet, all
the bells and whistles with 128 WEP.
So - what's the deal ? Should my hardware manufacturers config software be
giving the support for WPA or does windows itself need to have it in order
for it to function ? Not clear on that. Any ideas how to add WPA support to
SP1 which actually works and doesn't make my system run like it is chock
full of goo ? (No spyware, no malware, no viri, no nuttin' on the laptop
btw). Or do I have to bite the bullet and install the Feared SP2 on my
laptop ?
TIA for any ideas.
Rachael
Sponsored Links
Have you considered using MAC address filtering instead? If you always use
the same computers on the network it might be better than trying to
enforcing a protocol that isnt properly supported. Known as ACL (Access
control list) in the 3Com router
Start/Run ipconfig /all to see the physical (MAC) address for each network
interface
hth
philip ashley
"Rachael the Wiccan Rat" <none@badrats.co.uk> wrote in message
news:41549f65$0$20254$cc9e4d1f@news-text.dial.pipex.com...
the
> it).
Uninstall
to
> laptop ?
> TIA for any ideas.
> Rachael
Reply to Anonymous
"philip ashley" <p.ashley47RE@MOVEntlworld.com> wrote in message
news:AXc5d.254$lW2.218@newsfe6-gui.ntli.net...
> interface
> hth
Aren't MAC addresses easy to spoof ? I had considered it but I often have
friends come over with their laptops so WPA would be easier on the fly.
Rachael
Reply to Anonymous
agreed that MAC filtering isnt foolproof on its own, just another layer of
security.
maybe not appropriate in your case anyway
wpa adds an extra payload and i found some tweaking of the wireless
interface helped a lot
You could try setting the fragmentation and RTS/CTS thresholds a bit lower,
that has considerably stabilised my connection. I set both of mine to 2304
in the router and PCMIA laptop card.
http://www.wi-fiplanet.com/tutoria [...] hp/1468331
hth
philip ashley
news:4155c5c6$0$20253$cc9e4d1f@news-text.dial.pipex.com...
use
network
> > interface
> > hth
> Rachael
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > WPA hotfix problem
There are 1100 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
