Poor audio quality using music track with WMM 2.1
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.video (More info?)
I'm an absolute beginner at video. I'm trying to make a decent movie from DV
footage (Canon Optura 50) and WMM 2.1 My first movie has an audio track made
of a music song encoded in mp3 (192 kbps) and no footage sound (silenced).
The outcome is saved in AVI-DV in order tu later burn a DVD. While the video
is great, sound is of poor quality and noticeably distorted (sort of poor
dinamics and reverberation). However, if I play the project in WMM sounds
great! I play the movie and the songtrack with WMP. Seems to me that there is
an audio encoding problem within WMM.
Could yo help me? Thank for your support and patience.
Best regards.
Amando Hernádnez
www.imagenlibre.com
MM doesn't like mp3's, use a wma/wmv/wav instead, should then work.
Graham
Graham Hughes
MVP Digital Media
www.myvideoproblems.co.uk
www.dvds2treasure.com
www.simplydv.com
"amando" <amando@discussions.microsoft.com> wrote in message
news:065B2713-61DA-454E-B6B1-CD05931E4466@microsoft.com...
> DV
> made
> video
> is
> Best regards.
> Amando Hernádnez
> www.imagenlibre.com
Thanks, Graham, for your ansxer.
I did try wav and wma versions of the same soundtrack; the outcome is the
same. I also tried different, more compressed clip outputs, all yielding
worse video output (as expected) but far more better audio quality. The only
clip format that exhibits such poor audio quality is DV-AVI (PAL). I'm
running WXP home SP2, spanish version. My codec listing is as follows:
IMA ADPCM
MIcrosft ADPCM
MIcrosoft CCITT.G711
MIcrosoft GSM 6.10
DSP Group Truespeech
MSG723.acm
Windows Media Audio
Spiro Lab Telecom
Fraunhofer IIS MPEG Layer-3
Dvacm.acm
Indeo audio software
Conversor PCM de Microsoft
I'm really puzzled about this. Searching this forum and other Internet video
resources, I haven't found anything like this.
Best Regards.
Amando Hernádnez
www.imagenlibre.com
> Graham
> Graham Hughes
> MVP Digital Media
> www.simplydv.com
> > DV
> > made
> > video
> > is
> > Best regards.
> > Amando Hernádnez
> > www.imagenlibre.com
In order to show what the problem looks like, I have made an example clip
(just a few seconds) and saved in two different formats: compressed wmv and
AVI-DV. You can have a look at:
http://www.imagenlibre.com/video/Audio-problem.wmv
http://www.imagenlibre.com/video/Audio-problem-DV-PAL.a...
The first one has the soundtrack right. The second one (just a few seconds
due to server space constraints) has a defective soundtrack. Please, use
headphones yo appreciate sound differences.
The sound comes from a wma ripped from the original CD.
Thanks for trying to help. Best regards.
Amando Hernádnez
www.imagenlibre.com
> IMA ADPCM
> MIcrosft ADPCM
> MIcrosoft GSM 6.10
> MSG723.acm
> Windows Media Audio
> Spiro Lab Telecom
> Dvacm.acm
> Best Regards.
> Amando Hernádnez
> www.imagenlibre.com
> > Graham
> > Graham Hughes
> > MVP Digital Media
> > www.simplydv.com
> > > DV
> > > made
> > > video
> > > is
> > > Best regards.
> > > Amando Hernádnez
> > > www.imagenlibre.com
Related ressources
It's hard to get it from the 3 seconds. I suspect it may be lack of pc
resources, not allowing the avi to save proerly. Do you have other apps
running which you can turn off etc, see
http://www.myvideoproblems.com/Tutorials/OptimiseMyPcFo...
which is also true for capture problems.
Graham
Graham Hughes
MVP Digital Media
www.simplydv.com
news:F42E0E2A-5C90-4149-AD46-1B09E1F2E3BC@microsoft.com...
> and
> Amando Hernádnez
> www.imagenlibre.com
>> only
>> IMA ADPCM
>> MIcrosft ADPCM
>> MIcrosoft GSM 6.10
>> MSG723.acm
>> Windows Media Audio
>> Spiro Lab Telecom
>> Dvacm.acm
>> video
>> Best Regards.
>> Amando Hernádnez
>> www.imagenlibre.com
>> > Graham
>> > Graham Hughes
>> > MVP Digital Media
>> > www.simplydv.com
>> > > from
>> > > DV
>> > > track
>> > > made
>> > > (silenced).
>> > > the
>> > > video
>> > > poor
>> > > sounds
>> > > there
>> > > is
>> > > Best regards.
>> > > Amando Hernádnez
>> > > www.imagenlibre.com
Thanks, Graham, for your answer.
Well, I don't think so (of course, one is never sure of that). My PC is CPU
idle before generating the clip. It has 1 GB memory, P4 3GHz HT processor and
defragmented SATA disk. That the outcome is consistent (same audio quality
all over the clip and on several clips) makes me belive that the problem lies
on software rather than hw resources.
Best regards.
Amando Hernádnez
www.imagenlibre.com
> Graham
> Graham Hughes
> MVP Digital Media
> www.simplydv.com
> > and
> > Amando Hernádnez
> > www.imagenlibre.com
> >> only
> >> IMA ADPCM
> >> MIcrosft ADPCM
> >> MIcrosoft GSM 6.10
> >> MSG723.acm
> >> Windows Media Audio
> >> Spiro Lab Telecom
> >> Dvacm.acm
> >> video
> >> Best Regards.
> >> Amando Hernádnez
> >> www.imagenlibre.com
> >> > Graham
> >> > Graham Hughes
> >> > MVP Digital Media
> >> > www.simplydv.com
> >> > > from
> >> > > DV
> >> > > track
> >> > > made
> >> > > (silenced).
> >> > > the
> >> > > video
> >> > > poor
> >> > > sounds
> >> > > there
> >> > > is
> >> > > Best regards.
> >> > > Amando Hernádnez
> >> > > www.imagenlibre.com
You could try downloading a trial version of something like Ulead and see
how it fairs on producing an avi file. Thanks for the kind words.
Graham
Graham Hughes
MVP Digital Media
www.simplydv.com
news:D 404F531-C634-422B-8F86-D90709FFCBED@microsoft.com...
> CPU
> and
> lies
> Best regards.
> Amando Hernádnez
> www.imagenlibre.com
>> Graham
>> Graham Hughes
>> MVP Digital Media
>> www.simplydv.com
>> > clip
>> > and
>> > seconds
>> > use
>> > Amando Hernádnez
>> > www.imagenlibre.com
>> >> the
>> >> yielding
>> >> The
>> >> only
>> >> IMA ADPCM
>> >> MIcrosft ADPCM
>> >> MIcrosoft GSM 6.10
>> >> MSG723.acm
>> >> Windows Media Audio
>> >> Spiro Lab Telecom
>> >> Dvacm.acm
>> >> video
>> >> Best Regards.
>> >> Amando Hernádnez
>> >> www.imagenlibre.com
>> >> > Graham
>> >> > Graham Hughes
>> >> > MVP Digital Media
>> >> > www.simplydv.com
>> >> > > movie
>> >> > > from
>> >> > > DV
>> >> > > track
>> >> > > made
>> >> > > (silenced).
>> >> > > the
>> >> > > video
>> >> > > of
>> >> > > poor
>> >> > > sounds
>> >> > > that
>> >> > > there
>> >> > > is
>> >> > > Best regards.
>> >> > > Amando Hernádnez
>> >> > > www.imagenlibre.com
Ask the community
