Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > USB Connection Problem (Fuji S3000)
Forum Computer Peripherals : Digital Cameras - USB Connection Problem (Fuji S3000)
Archived from groups: alt.comp.periphs.dcameras (More info?)
I've had an S3000 for about a year that I use on rare occasions (just don't
take that many pictures). I've never had a problem with it until now.
Right before Christmas I got it out and found that it had been put into its
case with camera turned on (and power save off). So the batteries had
obviously been run to zero. I installed new batteries, reset the time/date
and a couple of other trivial items and took some pictures without a hitch.
But when I connected the camera to my computer nothing happened. The
computer acted as if there were no USB devices connected and my camera did
not go into USB mode as it normally does when turned on while connected to a
USB port.
I have reinstalled the drivers, downloaded and installed new drivers, put in
brand new batteries, checked everything that I could find to check, etc.
without help. I am now convinced that it is either a camera problem or a
cable problem as I have connected the camera to two other computers (both
running XP), one with the correct Fuji drivers installed and one without the
Fuji drivers installed. In neither case would the camera go into USB mode or
did the other computers have any awareness of a USB connection having been
made.
At this point I don't know what to do but to start an "Easter egging
process" - probably first by replacing the camera's USB cable (which doesn't
appear to be a common one as far as I can tell). Can anyone think of
anything else to try before I start spending money.
Thanks.
dave (new guy here on alt.*.dcameras)
Sponsored Links
is there some sort of "mode' or "port" setting that needs to be turned
on from within the camera menu (or more likely buried in a third level
sub menu) to enable the camera's "connect to computer" ability?
>USB port.
>made.
>Thanks.
Reply to Anonymous
On Sun, 26 Dec 2004 17:12:16 GMT, "Dave Lee"
>Thanks.
I would just buy a card reader, it's cheaper and faster.
Reply to Anonymous
Re: Attached
It has a "USB Mode" with two options - one for just downloading pictures and
one which allows some kind of webcam operation (never tried it). But neither
mode seems to be "alive" and the camera "USB mode" is always in one of those
two states. From all my experience (and the documentation) powering on the
camera while connected to a USB port is all that is required (till now
anyway).
Thanks.
dave
<nospam@comcast.com> wrote in message
news:p3uts0dljfk20pvess32ch1s5qod8nsmdo@4ax.com...
don't
its
time/date
hitch.
did
to a
> >USB port.
in
the
or
been
> >made.
doesn't
> >Thanks.
Reply to Anonymous
"Dave Lee" <DaveLeeNC@ix.REMOVE.netcom.com> wrote in message
news:QhCzd.2738$qf5.918@newsread3.news.atl.earthlink.net...
> don't
> its
> time/date
> hitch.
> a
> USB port.
> in
> the
> or
> made.
> doesn't
> Thanks.
Read Page 97-99 of the camera manual or this PDF.
http://www.fujifilm.com/JSP/fuji/e [...] tid=664271
It Says:
Set the "USB MODE" setting in the "SET-UP" menu to DSC (?P.77, 78).
CSM1
http://www.carlmcmillan.com
Reply to Anonymous
This camera uses an XD card and I am running off a laptop. I'm not familiar
with card reader's. But just did a quick Google search and you are correct -
that is probably better than my proposed Easter Egg approach.
Thanks.
dave
<tekfull@yahoo.com> wrote in message
news:aetts0lu0va4tivbg2biq2m6hnp3intfua@4ax.com...
doesn't
> >Thanks.
Reply to Anonymous
Re: Attached
Thanks - I'm familiar with that but, unfortunately, proper setting of this
set-up option isn't a solution to this particular problem.
dave
"CSM1" <nomoremail@nomail.com> wrote in message
news:5ZCzd.3146$F67.2251@newssvr12.news.prodigy.com...
> > don't
> > its
> > time/date
> > hitch.
did
to
> > a
> > USB port.
put
> > in
(both
> > the
mode
> > or
been
> > made.
> > doesn't
> > Thanks.
> It Says:
> CSM1
Reply to Anonymous
On Sun, 26 Dec 2004 17:58:25 GMT, "CSM1" <nomoremail@nomail.com>
wrote:
Huh... read a manual?? Is that pile of papers that came with the
camera relevant?? Doooh!!
>> don't
>> its
>> time/date
>> hitch.
>> a
>> USB port.
>> in
>> the
>> or
>> made.
>> doesn't
>> Thanks.
>http://www.fujifilm.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=687359&prodcat=628338&sscucatid=664271
>It Says:
>CSM1
Reply to lefty
The manual also says to install the usb driver on the computer and set the
camera to DSC not PC control.
CSM1
"lefty" <wpm302@hotmail.com> wrote in message
news:i84us0p35gomrr809igpa2nvoj75usoj7h@4ax.com...
> >> don't
> >> its
> >> time/date
> >> hitch.
did
to
> >> a
> >> USB port.
put
> >> in
etc.
a
(both
without
> >> the
mode
> >> or
been
> >> made.
> >> doesn't
> >> Thanks.
> >It Says:
> >CSM1
Reply to Anonymous
RE: > The manual also says to install the usb driver on the computer and set
the
> CSM1
Have tried both (they are both USB modes so both should be "USB aware" -
there is no other mode except PC and DSC). Neither seems to be "alive" in
this case (which is the problem).
dave
news:HwEzd.8721$wi2.3566@newssvr11.news.prodigy.com...
> CSM1
> > >> don't
into
> > >> its
> > >> time/date
> > >> hitch.
camera
> did
connected
> to
> > >> a
> > >> USB port.
> put
> > >> in
> etc.
or
> a
> (both
> without
> > >> the
> mode
> > >> or
> been
> > >> made.
> > >> doesn't
> > >> Thanks.
> > >It Says:
> > >CSM1
Reply to Anonymous
There are 1271 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
