Tom's Hardware > Forum > Games General > Games General Discussions > Help - set resolution too high for my monitor
Archived from groups: alt.games.half-life (More info?)
Hi, I hope someone can help, I have installed a new graphics card;
wanting to see how for I could push the resolution I set it to 1280 x
690 in the video options in HL2. Problem is my monitor can't cope and
switched itself off - now I cannot see the screen to change it back.
Aggghhhhhhh what do I do now?
Sponsored Links
boot into safe mode, i think that is 640x480.
remove the video card drivers and reboot to normal windows, res should
be 800x600.
reinstall drivers.
before selecting a higher or non-standard res tick the show only
supported resolutions box [or words to that effect].
dr ratt
trust me.
i know what i'm doing.
Message edited by Fredi on 10-09-2007 at 08:07:36 PM
Reply to Anonymous
I've never tried this with HL2, however, the commandline switch "-width
640" in HL1 would set your screen res to 640x480 .. it's worth a go.
Ben Cottrell AKA Bench
Message edited by Fredi on 10-09-2007 at 08:07:47 PM
Reply to Anonymous
Load steam....go to hl2 and right click and select properties....
Then click launch options...and type "-autoconfig" without the
quotes....but
remember to delete that after you have reset ur settings...otherwise
ur
settings will always "default" everytime u play the game...
Message edited by Fredi on 10-09-2007 at 08:07:56 PM
Reply to Anonymous
go buy a new monitor that can handle it
<b.woolf> wrote in message
news:1123356314.781430.30860@g43g2000cwa.googlegroups.com...
Message edited by Fredi on 10-09-2007 at 08:08:06 PM
Reply to BigJim
Craig you are a star - thank you so much, I am now in, and have changed
the video settings (have learnt a valuable lesson not tinker!). Thanks
also to everyone else that replied (especially dr ratt). I did try all
suggestions including the command line switch, without much luck. I
think this was because steam launches before HL2, I managed to get
steam to launch in 640x480 mode but it would still launch HL2 in high
rez. Anyway enough chat - problem sloved thanks again for your help
guys.
Reply to Anonymous
Reboot computer into Safe Mode then reset the video driver and reboot!
Fixed in a jiffy.
Reply to Anonymous
That was the first thing I tried - steam still starts HL2 in the high
rez mode
Reply to Anonymous
There are 966 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
