Archived from groups: microsoft.public.windowsxp.video (More info?)
I have a very annoying problem. Withe some downloaded movies, usually AVI
movies, the computer momentarily crashes the explorer, and then reloads in
about 10 seconds when I open the folder where they are located.It takes
about 5 seconds for the crash to occure It only happens if i actually touch
the file with the pointer or click on it once not opening the file but just
clicking on it once. The error messige that I get just before the crash is
"The exception Integer division by zero" occures and when I say OK the
explorer crashes momentarily and then reloads all the Icons in the tray and
bottom right corner, its wierd and only happens on certain downloaded
movies. This is very annoying. Please help
Niles
"Are you still wasting your time with spam?...
There is a solution!"
Protected by GIANT Company's Spam Inspector
The most powerful anti-spam software available.
http://www.giantcompany.com
If the files in question have never played correctly, I'd definitely go with
the corrupted probability.
Cari (MS-MVP)
Printing & Imaging
"nilesnormore" <nilesnormore@rogers.com> wrote in message
newsm2OwDWqFHA.3160@TK2MSFTNGP14.phx.gbl...
> touch the file with the pointer or click on it once not opening the file
> but just clicking on it once. The error messige that I get just before the
> crash is "The exception Integer division by zero" occures and when I say
> OK the explorer crashes momentarily and then reloads all the Icons in the
> tray and bottom right corner, its wierd and only happens on certain
> downloaded movies. This is very annoying. Please help
> Niles
> http://www.giantcompany.com >
The files are usually the ones I download with bitlord torrent downloader so
I don't know if that is the cause or if it's something elce
Also I tried two programs that are supposed to help me identify certain
codec problems, I tried "G-spot" and the other one is "Sherlock", which said
Divx for Blizard Decoder filter is broken. Gspot says I have multiple
codects for the same file both divx and xvid
"Cari (MS-MVP)" <Newsgroups1@coribright.com> wrote in message
news:ek%23iQuaqFHA.3836@TK2MSFTNGP12.phx.gbl...
> Does this happen with ALL AVI files?
> http://www.globetechnology.com/ser [...] leshooter/ >
> with the corrupted probability.
> Cari (MS-MVP)
> Printing & Imaging
>> in about 10 seconds when I open the folder where they are located.It
>> takes about 5 seconds for the crash to occure It only happens if i
>> actually touch the file with the pointer or click on it once not opening
>> the file but just clicking on it once. The error messige that I get just
>> before the crash is "The exception Integer division by zero" occures and
>> when I say OK the explorer crashes momentarily and then reloads all the
>> Icons in the tray and bottom right corner, its wierd and only happens on
>> certain downloaded movies. This is very annoying. Please help
>> Niles
>> http://www.giantcompany.com >>
Sounds like you need to re-find and re-install the Blizard Decoder.... Try
uninstalling it first and seeing what happens without it.
Cari (MS-MVP)
Printing & Imaging
news:%23%23SzjtMrFHA.3620@TK2MSFTNGP10.phx.gbl...
> so I don't know if that is the cause or if it's something elce
> said Divx for Blizard Decoder filter is broken. Gspot says I have multiple
>> http://www.globetechnology.com/ser [...] leshooter/ >>
>> Cari (MS-MVP)
>> Printing & Imaging
>>> AVI movies, the computer momentarily crashes the explorer, and then
>>> reloads in about 10 seconds when I open the folder where they are
>>> located.It takes about 5 seconds for the crash to occure It only happens
>>> if i actually touch the file with the pointer or click on it once not
>>> opening the file but just clicking on it once. The error messige that I
>>> get just before the crash is "The exception Integer division by zero"
>>> occures and when I say OK the explorer crashes momentarily and then
>>> reloads all the Icons in the tray and bottom right corner, its wierd and
>>> only happens on certain downloaded movies. This is very annoying. Please
>>> help
>>> Niles
>>> http://www.giantcompany.com >>>
