Problem with setting up advanced connection
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hello, I have a problem I try to set up an "Advanced Conncetion". When I try to set up to "Accept a new connection" in the wizard I get the following error:
Incoming Connections Warning!
"Incoming Connections depend on the Routing and Remote Access service which was unable to start. For more information, check the event log.
In the viewer I get the following message:
The Routing and Remote Access service terminated with service-specific error 499 (0x1F3).
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
When I tag "http://go.microsoft.com/fwlink/events.asp." It gives me this information:
Details
Product: Windows Operating System
Source: Service Control Manager
Version: 5.0
Component: System Event Log
Symbolic Name: EVENT_SERVICE_EXIT_FAILED_SPECIFIC
Message: The %1 service terminated with service-specific error %2.
Explanation
The specified service stopped unexpectedly with the error indicated in the message. Windows does not recognize the service's error code.
User Action
To display the service-specific error code in the Service_Exit_Code field, at the command line, type
sc query service name
The information displayed might help you troubleshoot why the error occurred.
Version: 5.2
Explanation
User Action
I do not know what this means. Ido know in "Services" that when I try to start "Routing and Remote Access" in properties I get this error.
"Windows could not start the Routing and Remote Access on Local Computer. For more information, review the syste. Event Log. If this is a non-microsoft service, contact the service vendor, and refer to service-specific error code 499."
I cannot find a error code 499 on the Microsoft web site.
Can someone help????
Thanks
4 answers Last reply
More about problem setting advanced connection
  1. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Go to Services and check to make sure that the Remote Access
    Connection Manager service is enabled... If so, try starting it...
    Then try to recreate your Incoming Connection.
    Jeffrey Randow (Windows Net. & Smart Display MVP)
    jeffreyr-support@remotenetworktechnology.com
    Please post all responses to the newsgroups for the benefit
    of all USENET users. Messages sent via email may or may not
    be answered depending on time availability....
    Remote Networking Technology Support Site -
    http://www.remotenetworktechnology.com
    Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
    >Details
    >Version: 5.0
    >Explanation
    >User Action
    >Version: 5.2
    >Explanation
    >User Action
    >Thanks
  2. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    OK, I tried it and still no go!
  3. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Other possible solutions:
    (from google)
    Check in the system32 directory for MSJETOLEDB40.DLL. This file may
    be missing or named incorrectly. A file by the name of MSJETOL1.DLL
    may exist. This is the 8.3 name for MSJETOLEDB40.DLL. If
    MSJETOL1.DLL is there, rename it to the long file
    name above. If it isn't there, copy it from another machine. After
    the file is renamed or copied, register the DLL by typing "regsvr32
    MSJETOLEDB40.DLL".
    RRAS should now start.
    Jeff Q
    On Sat, 17 Apr 2004 07:16:06 -0700, "Mcrum"
  4. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Jeff,
    Thaks for your help but it still is a no go. The .dll was correct. Anything else?
Remote Access Connection Windows XP
