Archived from groups: alt.video.dvd.software,alt.video.dvd.tech,rec.video.desktop,rec.video.dvd.tech (More info?)
While I create my own DVDs quite happily, and have learnt a lot, I have a
file a BBC documentary that I missed taping that I now have got as a Xvid
file, with a unknown, supposedly audio format, an unknown LPCM. Wityh
TMPGEnc it leaves the audio as a on-off buzzing with no voice.
I need this on DVD, no luck extracting with VDub, the audio wav filke plays
ok, but it cannot remian ok when authored with RMPG DVD Author or Ulead
DVDMF3.
Is it possible, and preferbaly not too technical to convert the file to
soemthing a DVDauthoring program can deal with?
GSpot tells me it is AC3 at 48000khz and 192 bit.
Do I need a plugin perhaps?
DVDMF3.
