PAL to NTSC conversion, how?
Archived from groups: rec.video.desktop (More info?)
Hi
Can some one please tell me how to convert a PAL dvd to an NTSC one
Thanks
4 answers Last reply
More about ntsc conversion
  1. Archived from groups: rec.video.desktop (More info?)
    "news" <email@nowhere.com> wrote in message news:<T73Yc.279$CJ4.108@newsfe6-win.ntli.net>...
    > Hi
    > Thanks
    You'd think someone would have written a one-click method for doing
    this, wouldn't you, but I'm afraid no such luck (at least I haven't
    been able to find anything).
    What I've done in the past is to extract the titles to AVIs that you
    want to convert using DVD2AVI or some such program. Then use Tmpgenc
    to convert these PAL MPEG2 files to NTSC (just use the standard DVD
    template). The results are not spectacular, particularly if there is
    a lot of motion in the original movies, but it can be acceptable.
    Extract the audio AC3s using VirtualDubMod, then piece it all back
    together using any DVD authoring program.
  2. Archived from groups: rec.video.desktop (More info?)
    >>Hi
    >>Thanks
    Hi,
    I found a set of AviSynth (2.5 and more) which converts NTSC --> PAL
    with very decent results.
    Assuming that your d2v file generated by DVD2AVI is 'mymovie.d2v' and
    the script you can find at the end is saved unter 'converter.avsi' I
    have the following AviSynth file to convert NTSC --> PAL
    import("<your path>\converter.avsi")
    MPEG2Source("<your path>\mymovie.d2v")
    ConvertToYUY2(interlaced=true)
    AddBorders(0,48,0,48)
    converter(720,576,true,20,false,false)
    Maybe you can reengineer this set of functions to make it work the other
    way round. It looks a little tricky but using the AviSyth documentation
    on their internet site it shouldn't be to difficult to understand.
    Good luck
    Andreas
    Here ist the functionality (it's not nicely edited, sorry)
    function converter(clip input, int x, int y, bool TFF, int "combth",
    bool "speedup", bool "show")
    function kernelbob(clip a, int th)
    f=a.
    \kerneldeint(order=0, sharp=true, twoway=true, threshold=th)
    e=a.separatefields.trim(1,0).weave.
    \kerneldeint(order=1, sharp=true, twoway=true, threshold=th)
    interleave(f,e)
    function speeduphybrid(clip i, int width, int height, bool debug)
    comb = telecide(i,order=1,post=0).decimate(5)
    f = framerate(comb)
    film = comb.lanczosresize(width,height).assumefps(25,true)
    film = (debug == false) ? film : film.subtitle("film -> IVTC -> speedup")
    video = i.kernelbob(5).lanczosresize(width,height).
    \convertfps(2*f).assumefps(50,true).separatefields.selectevery(4,0,3).weave
    video = (debug == false) ? video : video.subtitle("video -> blending ->
    speedup")
    conditionalfilter(comb,video,film,"iscombed(combthr)","=","true")
    function speedupfilm(clip i, int width, int height, bool debug)
    film = i.assumefps(25,true).lanczosresize(width,height)
    film = (debug == false) ? film : film.subtitle("film -> speedup")
    return film
    function converthybrid(clip i, int width, int height, bool debug)
    \changefps(50).separatefields.selectevery(4,0,3).weave
    film = (debug == false) ? film : film.subtitle("film -> IVTC -> convert")
    \convertfps(50).separatefields.selectevery(4,0,3).weave
    video = (debug == false) ? video : video.subtitle("video -> blending")
    conditionalfilter(convertfps(comb,25),video,film,"iscombed(combthr)","=","true")
    function convertfilm(clip i, int width, int height, bool debug)
    film = i.lanczosresize(width,height).
    film = (debug == false) ? film : film.subtitle("film -> convert")
    return film
    combth = default(combth,20)
    global combthr=combth
    speed = default(speedup,true)
    debug = default(show ,false)
    input = (TFF == true) ? input.assumetff : input.assumebff
    speedupout = (framerate(input) < 26) ?
    \speedupfilm(input,x,y,debug) : speeduphybrid(input,x,y,debug)
    convertout = (framerate(input) < 26) ?
    \convertfilm(input,x,y,debug) : converthybrid(input,x,y,debug)
    final = (speed == true) ? speedupout : convertout
    final.resampleaudio(audiorate(input))
  3. Archived from groups: rec.video.desktop (More info?)
    But, can VirtualDubMod extract it as an .ac3? Because if it extracts
    it as a .wav, you shall not be able to re-multiplex without a
    conversion to .ac3 format. Is there a way to convert from an Ac3
    encoded .wav to an .ac3, without any re-encoding? (Should be easy, but
    I don't know of a program that does this).
  4. Archived from groups: rec.video.desktop (More info?)
    Bariloche <bariloche@bariloche.com> wrote in message news:<aa2cj0pc3b5rke8bsui0i0sgkdcbn2kh20@4ax.com>...
    VirtualDubMod can extract the audio stream as is (i.e. not convert to
    ..wav), so you don't have to do any conversion - rip out the .ac3 and
    then use as is with your NTSC video.
Tuner Cards Desktops Video Graphics
