Problems with setting up Remote Desktop from XP Pro and XP..
Pablo
44
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have XP Pro on my laptop, and would like to be able to
connect to the main PC using remote desktop. The main PC
has XP Home.
I am unable to find how to make a connection on the XP
Home PC, and I was wondering if it was possible.
I have a normal network connection between them, and this
is running fine.
They connect to each other using a wireless router.
I did have XP Pro on them both at one point, and this
worked fine with the router.
I know the problems must be on the user side [me], and
would love some help setting it up.
Thanks in advance.
G
Guest
Guest
I'm almost in the same boat.
I have XP Pro installed at home hanging off a wireless/router/switch port[using UTP to switch]. The box can access the internet through the wireless/router/switch. IP number is assigned by the router/switch. I "think" I've enabled the remote stuff properly, but I'm unable to dial in to the XP Pro box and get my mail.
I've tried a W2K Pro laptop and a XP home laptop. I'm unable to get past the authenication to get my mail off the ISP server.
[ISP does not provide dial-in service... only broadband]
G
Guest
Guest
You can not access/control an XP Home box using Remote Desktop from another PC. An alternative is
UltraVNC. Go to http://ultravnc.sourceforge.net/ for the server and client software. If you want to
do this over the public internet then I also suggest you install the encryption plug-in for
UltraVNC. Get that at http://home.comcast.net/%7Emsrc4plugin/
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Pablo" <anonymous@discussions.microsoft.com> wrote in message
news:470901c42bbc$06f545c0$a301280a@phx.gbl...
> has XP Home.
> is running fine.
> Thanks in advance.
G
Guest
Guest
So I take your trying to reach the XP Pro box at home from a remote location using either a W2K
laptop or a XP Home laptop, correct?
If so do you have TCP Port 3389 forwarded/opened to the private LAN IP of the XP Pro box on the home
router?
Are you calling the correct public IP for your router?
"Felton" <anonymous@discussions.microsoft.com> wrote in message
news:B06ADED7-02D8-4735-A757-36ACFE92E18D@microsoft.com...
G
Guest
Guest
What "remote stuff" are you trying to do? VPN or RAS... If so,
search for Incoming Connections in Windows Help and Support.
Jeffrey Randow (Windows Net. & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Mon, 26 Apr 2004 12:06:03 -0700, Felton
