Archived from groups: microsoft.public.pocketpc (
More info?)
I'm sorry to jump in on this thread but I saw Axim 3i and though
someone could help?
I'm not sure what happened, something I did I'm sure, but now when
I sync my calendar etc it does not show past appts and such. They are
all there in Outlook but don't sync over. ???
In my Desktop ActiveSync/Options/Settings, I have "syncronize all
appointments" checked.
any help sure appreciated.
jfergus@tampabay.rr.com
"Harry" <Harry@SomeDomain.com> wrote in message
news:iak2b0tklo88s7qnme4scuu2r2qr43vevh@4ax.com...
> Thanks! Useful.
> The Dell Axim x3 doesn't have a coax plug for recharging... you have
> to use the cradle or special AC adapter. But recently they have made
> available this Emergency Power Adapter which should allow use of one
> of these battery packs.
> H.
> On Mon, 24 May 2004 04:43:12 +0800, "Carlo Ma. Guerrero [MVP]"
> <ppcsurfr@hotmail.com> wrote:
> >Which brings me to this article on Dale Coffing's site
www.pocketpcpassion.com...
http://www.pocketpcpassion.com/archive/casio/DennisWolf...
tteryExtender.htm
> >This is basically how it's supposed to be done... with a diode that
prevents
> >current from flowing back to the battery pack... but of course, you will
> >have to make some slight modifications as to how it conencts to your PPC.
> >Carlo Ma. Guerrero
> >Microsoft MVP, Mobile Devices
> >"Beverly Howard [Ms-MVP/MobileDev]" <BevNoSpamBevHoward.com> wrote in
> >message news:e191M2PQEHA.2716@tk2msftngp13.phx.gbl...
> >Additionally... think you will find that the ac power adapter shows it's
> >output at 5vdc.
> >Using the combo sync cable (that appears to have a coaxial power jack in
> >the connector, a common "4 Cell" battery holder (available for all sizes
> > from AA to D) gives a much less expensive and safer extender option
> >although there may be some minor efficiency losses.
> >Safer, because the device's internal circuitry will (to some degree)
> >handle voltage over/under/polarity issues.
> >Beverly Howard [MS MVP-Mobile Devices]
