Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Remote desktop disables my sound driver. any ideas ?
Forum Windows XP : Windows XP General Discussion - Remote desktop disables my sound driver. any ideas ?
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have a server computer (xp) with sound card +speakers.
I connect via remote desktop and as soon as i do it
removes the sound driver for playback. i can log onto the
server localy and the sound plays fine, i have tried
everything inc driver and a new sound card. any idea why
windows decides to remove the driver ?
Sponsored Links
This is a known issue.. The workaround is to start an audio
application (like Media Player) before you connect w/ Remote Desktop.
Once you connect, you should be able to maintain a connection to your
local audio device.
BTW: Make sure you have Sound Redirection Left at Remote Computer...
Jeffrey Randow (Windows Net. & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Mon, 10 May 2004 05:34:58 -0700, "Bri"
Reply to Anonymous
Thanks Jeffrey
I was hoping that there was a cure for this problem, I
will just leave wmediaplayer running and see how that
goes.
Brian
>-----Original Message-----
audio
Remote Desktop.
connection to your
>local audio device.
Remote Computer...
benefit
not
the
why
Reply to Anonymous
The fix is coming... So there is hope.. :)
On Thu, 13 May 2004 06:45:19 -0700,
>Thanks Jeffrey
>goes.
>Brian
>audio
>Remote Desktop.
>connection to your
>>local audio device.
>Remote Computer...
>benefit
>not
>the
>why
Reply to Anonymous
Hello, dear music lovers away from home! :sol:
Before I go any further, I must offer this disclaimer: there is no guarantee that this will actually work every time. It is merely a theory that I have.
Bring [remote sound] to this computer
When I leave the house, I leave the computer logged on under someone else's name. When I get to work, I log on as me and just kick off the other "user". (It brings up a box saying something like "User X is logged on. If you continue, X has to disconnect. Are you sure you want to continue?" "Yes" is the response we like here.) The audio has worked every time so far since I started doing that.
Of course, I usually fail to do consecutive Remote Desktop sessions; I just do one at work and then come back home. Chances are, if you do consecutive remote sessions, the audio will only work so many times before, one time, you log on and, lo and behold, there's that same problem again. But I may try, perhaps later this month when I house-sit for my aunt up north, to enable a remote connection for another user on this computer and then just keep kicking off the other user or myself as necessary. Or perhaps someone else can try this in the meantime and see if it works. :whistle:
Again, this is just a theory. I still fail to understand the logic of audio not always working the way it ought to via Remote Desktop. But I feel this is worth a shot.
Best of luck to anyone who has had this problem with the audio drivers and Remote Desktop.
Peace,
~C.A.~
Reply to Cheshire Adams
Eww.......sorry, that trick has suddenly ceased to work today.
GRRRR!!!!
~C.A.~
Okay, I put a password on a rarely-used account on here and tried logging on as that user. The audio worked when I did that. I changed back over to myself, and it gave me the same old "Cannot open the audio device" error. Changed back to the other user, it worked! So, today, at least, the audio worked as it should on the one account but not on mine.
I can only think that it has something to do with how long a user has been logged on for one sitting.....because my username, the audio for which had been working for a while and then today suddenly didn't, had been logged on for a while, whereas the freshly logged-on (via Remote Desktop) alternate account had wonderfully fine audio. (Although I had to go through a few media players because they kept crashing for some reason, but that's another story.)
Perhaps you shall have to fully log off your user.....in other words, don't merely close Remote Desktop, but actually "Log Off" via the start menu.....and then log on again. Bit of a pain, perhaps.....but I'll try it, possibly tomorrow.
Further bulletins as events warrant.....
~C.A.~
- 0 +
Back from the dead...but has anyone found a solution for this?
Reply to poldim
Hey again.
That last thing I said last time I posted....about fully logging off and logging in again?
That works.
At least for me it does.
Kind of a quirk, though: When you're back "home," if you've logged in remotely and disconnected without logging off and then connected "here," the home computer will, for some reason, put password prompts on the other users, even though they don't have passwords. This is, of course, fixed by fully logging off your user account (and you can log in again as desired without consequence).
I've been doing this for some time now. I still don't know exactly what causes the problem, but I got a good workaround for it anyway. And the problem doesn't always occur. Often, it goes quite a number of flawless days without a hitch. But when there is a hitch, it's easily left in the dust.
Lotsa luck. I'm off to groom Lucy (the cat). Apparently, this thing will e-mail me if there's a response.
Rock on,
~C.A.~
http://i81.servimg.com/u/f81/13/41/62/19/th/lucy_e11.gif
There are 834 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
