Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems with Win XP Remote Desktop Connection on a Workgr..
Forum Windows XP : Windows XP General Discussion - Problems with Win XP Remote Desktop Connection on a Workgr..
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
We have 3 PC's at work running Win XP in a workgroup. The problem is when
all 3 PC's are left running Remote Connections over the web default to only
one PC which has all our user accounts on for sharing in the workgroup. I
have set all the listening ports different for each PC for example 100, 101,
and 102. I have opened ports 3389 and the listening ports on each PC's
Firewall! We connect to the net via a Dynamode R-ADSL-C4 Router! I've also
directed Public Port & Private Port 3389 and the listening ports to each PC'
s static IP address in the Virtual server on the router!
I've tried the remote console and tsweb to connect but it still defaults to
the same PC. When I use (http://ip address:listening port/tsweb) each
listening ports opens the connection page any other port number doesn't, so
the router must be working correctly! I have a funny feeling it may be
something to do with my settings for the router forwarding!
Hope somebody can help
Thanks in advance
Sponsored Links
See if this helps:
http://members.cox.net/ajarvi/Remo [...] PC_RD.html
> when all 3 PC's are left running Remote Connections over the web
> default to only one PC which has all our user accounts on for sharing
> in the workgroup. I have set all the listening ports different for
> each PC for example 100, 101, and 102. I have opened ports 3389 and
> the listening ports on each PC's Firewall! We connect to the net via
> a Dynamode R-ADSL-C4 Router! I've also directed Public Port &
> Private Port 3389 and the listening ports to each PC' s static IP
> defaults to the same PC. When I use (http://ip address:listening
> port/tsweb) each listening ports opens the connection page any other
> port number doesn't, so the router must be working correctly! I have
> a funny feeling it may be something to do with my settings for the
> router forwarding!
> Thanks in advance
Reply to Anonymous
- 0 +
Top Man
Now seems to be working fine :-)
Cheers
"Lanwench [MVP - Exchange]"
<lanwench@heybuddy.donotsendme.unsolicitedmail.atyahoo.com> wrote in message
news:uUr4nLaPEHA.1276@TK2MSFTNGP11.phx.gbl...
> See if this helps:
> > router forwarding!
> > Thanks in advance
Reply to Ryan
Glad it worked!
Ryan wrote:
> Top Man
> Cheers
> message news:uUr4nLaPEHA.1276@TK2MSFTNGP11.phx.gbl...
>> See if this helps:
>>> is when all 3 PC's are left running Remote Connections over the web
>>> sharing in the workgroup. I have set all the listening ports
>>> different for each PC for example 100, 101, and 102. I have opened
>>> ports 3389 and the listening ports on each PC's Firewall! We
>>> each PC' s static IP address in the Virtual server on the router!
>>> have a funny feeling it may be something to do with my settings for
>>> Thanks in advance
Reply to Anonymous
- 0 +
Dear Lanwench
I'm composing this mail remotely from home on my works PC using the Remote
Desktop Console!!! Cooool!!!
The only problem now is with the web based version (tsweb)!!! It seems you
cant specify the remote port, I've configured the router to redirect port
number 3390 to 3389 on IP address 10.0.0.3
So when I type http://52.10.194.206:19673/tsweb/Default.htm the default web
connection page appears but you cant then enter a port number! If I type
http://52.10.194.206:3389/tsweb/Default nothing happens because it cant find
the tsweb page!
Hope you can help me some more
Thanks again ;-)
news:O9UhADePEHA.640@TK2MSFTNGP12.phx.gbl...
> Glad it worked!
> Ryan wrote:
> > Top Man
> > Cheers
> >> See if this helps:
> >>> Thanks in advance
Reply to Ryan
Ryan wrote:
> Dear Lanwench
> Remote Desktop Console!!! Cooool!!!
> seems you cant specify the remote port, I've configured the router to
> redirect port number 3390 to 3389 on IP address 10.0.0.3
> default web connection page appears but you cant then enter a port
> number! If I type http://52.10.194.206:3389/tsweb/Default nothing
> happens because it cant find the tsweb page!
Hmmm - not sure; I rarely use TSWeb (esp. for workstations) as I find the RD
client so much nicer & full-featured. Perhaps someone else will post?
> Thanks again ;-)
> message news:O9UhADePEHA.640@TK2MSFTNGP12.phx.gbl...
>> Glad it worked!
>> Ryan wrote:
>>> Top Man
>>> Cheers
>>>> See if this helps:
>>>>> web default to only one PC which has all our user accounts on for
>>>>> to each PC' s static IP address in the Virtual server on the
>>>>> router!
>>>>> other port number doesn't, so the router must be working
>>>>> correctly! I have a funny feeling it may be something to do with
>>>>> Thanks in advance
Reply to Anonymous
You need to modify the HTML in the web page to specify the altered port.
There's a wealth of information available here:
http://remotenetworktechnology.com [...] ork%5FHome
So--where's what we need?
Here we go:
http://remotenetworktechnology.com [...] bClient#h4
"Ryan" <RAnderton_PSS@hotmail.com> wrote in message
news:ODAP1YgPEHA.3264@tk2msftngp13.phx.gbl...
> Dear Lanwench
> you
> web
> find
> the tsweb page!
> Thanks again ;-)
> message
>> Glad it worked!
>> Ryan wrote:
>> > Top Man
>> > Cheers
>> >> See if this helps:
>> >>> Thanks in advance
Reply to Anonymous
- 0 +
Thanks Bill
You don't know where the below code should be added, do you? I've tried it
everywhere in the default.htm file but it returns errors!!!
MsRdpClient.AdvancedSettings2.RDPPort = 3389
Thanks in advance
Ryan
"Bill Sanderson" <Bill_Sanderson@msn.com.plugh.org> wrote in message
news:uarxjboPEHA.3348@TK2MSFTNGP09.phx.gbl...
> Here we go:
> > Dear Lanwench
Remote
> > you
port
> > web
> > find
> > the tsweb page!
> > Thanks again ;-)
> > message
> >> Glad it worked!
> >> Ryan wrote:
> >> > Top Man
> >> > Cheers
> >> >> See if this helps:
other
> >> >>> Thanks in advance
Reply to Ryan
I've never needed to use this code, I'm afraid.
You need to modify the 3389 for your actual chosen port, of course.
I'm looking, but I don't seem to have IIS running on this machine at the
moment, and I can't look at the file. As I recall there is a set of
parameters--including those which determine whether printers or drives are
redirected. Amongst those is what I'd think.
news:ed$5FJZQEHA.2132@TK2MSFTNGP11.phx.gbl...
> Thanks Bill
> it
> Thanks in advance
> Ryan
>> Here we go:
>> > Dear Lanwench
> Remote
>> > you
> port
>> > web
>> > type
>> > find
>> > the tsweb page!
>> > Thanks again ;-)
>> > message
>> >> Glad it worked!
>> >> Ryan wrote:
>> >> > Top Man
>> >> > Cheers
>> >> >> See if this helps:
>> >> >>> web
>> >> >>> to
> other
>> >> >>> for
>> >> >>> Thanks in advance
Reply to Anonymous
- 0 +
Thanks Bill
Your a top Man :-)
It seems to be working, I'll try it properly 2night!!
Cheers
news:Obez2RZQEHA.4052@TK2MSFTNGP10.phx.gbl...
> > Thanks Bill
> > it
> > Thanks in advance
> > Ryan
port.
> >> Here we go:
> >> > Dear Lanwench
> > Remote
seems
> >> > you
> > port
default
> >> > web
> >> > type
cant
> >> > find
> >> > the tsweb page!
> >> > Thanks again ;-)
> >> > message
> >> >> Glad it worked!
> >> >> Ryan wrote:
> >> >> > Top Man
> >> >> > Cheers
in
> >> >> >> See if this helps:
problem
> >> >> >>> web
opened
> >> >> >>> to
router!
address:listening
> > other
> >> >> >>> for
> >> >> >>> Thanks in advance
Reply to Ryan
You need to put in the file where you see the other MsRDPClient
options...
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Mon, 24 May 2004 14:23:10 +0100, "Ryan" <RAnderton_PSS@hotmail.com>
wrote:
>Thanks Bill
>Thanks in advance
>Ryan
>> Here we go:
>http://remotenetworktechnology.com/ow.asp?Remote%5FNetwork%5FHome%2FTerminalServices%2FWebClient#h4
>> > Dear Lanwench
>Remote
>> > you
>port
>> > web
>> > find
>> > the tsweb page!
>> > Thanks again ;-)
>> > message
>> >> Glad it worked!
>> >> Ryan wrote:
>> >> > Top Man
>> >> > Cheers
>> >> >> See if this helps:
>other
>> >> >>> Thanks in advance
Reply to Anonymous
There are 601 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
