Archived from groups: rec.video.desktop (
More info?)
eaglecrest@worldnet.att.net (Bill S.) wrote in
news:cd85bc1a.0409300759.1519d27e@posting.google.com:
> "GhostFaZ" <ghostfaz@no-spam-altern.org> wrote in message
> news:<415bc022$0$10410$ba620e4c@news.skynet.be>...
>> Hi,
>> I had no time to do other tests, but this week-end, I will try :
>> 1. to capture my tape directly with Scenalyzer
>> 2. try to extract only some scenes and check if the sound is
>> synchronized or not.
>> Bill told me to use Premiere to create the scenes but I think
>> that premiere is only able to capture in one file
>> My last possibility is to use the 11 Go file in Premiere to make
>> the montage Thanks
>> Thierry
> Gino Wrote:
>>In the ScenalyzerLive Options menu, under the "Stop Capturing"
>>tab, is this note: "You can set a time limit for the current
>>capture process in the menu 'Capture/set time limit' while the
>>program is capturing". I'm not capturing at the moment, but I do
>>see the "set time limit" command (greyed out) in the Capture menu.
>>HTH, Gino
> Gino,
> I have tried using that function, but all too often it stops
> capturing several minutes early. I think it runs off the counter
> on the preview screen, rather than the amount of time that has
> actually been captured to a file. In other words, if you want to
> capture 1 hour, and the program has been running for 5 minutes
> before you start, then the capture will only be 55 minutes long.
> I may be wrong on this point, but I do know for sure that the
> times I used it, the last few minutes of the program was almost
> always missing.
> And for Thierry, isn't Premiere a video editing program? If that
> is the case, then all you need to do is edit the file down to
> include only the scenes(s) you want, then have Premiere create a
> new AVI file.
> Bill
Thanks for the follow-up. As you can tell, I've never used the
feature. Too bad it doesn't really do the desired job.
I posted after my first post a remark about a brief experiment in
which I saw too much video, as though it added the time to my
starting time, rather than setting a total capture time. Of course,
this wasn't long enough to show the problem you noted above.
Guess I'll not bother with that technique myself
Gino
Gene E. Bloch (Gino) phone 650.966.8481
Call me letters find me at domain blochg whose dot is com
