G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
with XP Pro I usually connect with Remote Desktop Connection to a certain server without problems.
Now I also need the ability of connecting to another server, and cannot succeed.
I have tried to install the software using msrdpcli.exe at a Windows 95. It functions well, and I can connect to both servers.
When I try to install the same software at my XP Pro, I get the message, that it is already installed, but still I can only connect to the first server.
Trying to fix it, I wanted to remove the installation from XP and then reinstall it. But in the control panel, I cannot find the program in the list og programs that can be deleted.
I have then tried to explicitly delete the file mstsc.exe from in system32-folder. I succeed in the first place, but I can stil open the program from the start-menu, and after using it, it appears again in the system32-folder.
What can the problem be, and what can I do?
kirkegd
kirkegd
