Archived from groups: rec.video.desktop (More info?)
Has anyone here installed DVDstyler under Win98 and successfully burned a
dvd.iso file? I keep getting an error on the jpeg2yuv step of the burn
process and I can't figure out what might be causing it to fail.
At first I thought it was a problem with the command line exceeding the
128-character limit in DOS, but I wrote a batch file and use SUBST to shorten
the paths so the line is now only 115 characters and it still doesn't work.
I've tried putting other commands in the Jpeg2Mpeg field, like dir, cd, etc.,
and nothing will execute without an error. I've tried uninstalling and
reinstalling -- no luck. I'm about to give up on it.
