Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
i have a small office network sharing a dsl internet
connection. how can i access my pc (files, printer &
internet access) using a dial-up connection when i'm out
of the office?
Are you talking about calling the office PC (which has a modem attached) so you can access files,
etc from your PC? Or are you talking about accessing the office PC via the DSL connection from your
PC? Both are doable...
Configure RAS on Windows XP
Configure the desktop computer for incoming connections
1. Click Start, and then Control Panel.
2. Click the Network and Internet Connections icon and pick the Network Connections icon.
3. Double-click Make New Connection for the New Connection Wizard.
4. Select Advanced Connection under Network Connection Type and click Next.
4. Select Accept incoming connections and click Next.
5. Select the modem from the list of devices, and click Next.
6. Select either of the options for allowing Virtual Private Connections, and click Next.
7. Check the users you want to be able to authenticate when connecting to the desktop from the
device, and click Next.
8. Ensure the Internet Protocol (TCP/IP) check box is selected, click Next, and then Finish.
Call the phone number of the modem the PC is connected to from the remote PC...
Make sure your modem is setup for Auto Answer...
Otherwise use Remote Desktop to call the office PC (using its DSL connection) over the public
internet using the public IP assigned to the router (ie. the ISP assigned IP). Make sure TCP Port
3389 is forwarded to the private LAN IP of your office PC.
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com This posting is provided "AS IS" with no warranties, and confers no rights...
"jay" <anonymous@discussions.microsoft.com> wrote in message
news:1e4bb01c454d4$71b19580$a001280a@phx.gbl...
> of the office?
> thanks,
> jay
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.707 / Virus Database: 463 - Release Date: 6/15/2004
Al, thanks for your reply.
I intend to call the office PC (with modem) to access
files & resources. Can I also have access to the internet
connection of the office PC? The office PC is connected
to a LAN sharing a DSL internet connection.
Jay
>-----Original Message-----
Connection Wizard.
Next.
>http://www.microsoft.com/windowsxp/pro/using/howto/gomobil
e/remotedesktop/default.asp
> Al Jarvi (MS-MVP Windows Networking)
>The MS-MVP Program - http://mvp.support.microsoft.com >This posting is provided "AS IS" with no warranties, and
message
>> of the office?
>> thanks,
>> jay
You could enable ICS on the PC to do that. Note you really need to contact your local network
administrators about this. It may be against company policy to both connect to the PC with a RAS
connection and enable ICS.
news:1e9de01c455c1$9d722890$a501280a@phx.gbl...
> Jay
> Connection Wizard.
> Next.
>>The MS-MVP Program - http://mvp.support.microsoft.com >>This posting is provided "AS IS" with no warranties, and
> message
>>> of the office?
>>> thanks,
>>> jay
Version: 6.0.708 / Virus Database: 464 - Release Date: 6/18/2004
Thanks, Al!
message
internet
>> Jay
