Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Thanks so much. My problem has been solved.
"Mark Dormer" <markd@mvpsx.org> wrote in message
news:O6rFnRRVEHA.3988@tk2msftngp13.phx.gbl...
> It is certainly possible
> How to do it is the choice you have to make.
> You could use a VPN
> You could use terminal services like Remote Desktop or VNC
> You could use file and printer sharing ( not secure at all, do not do
this)
> I acces mine like this using terminal services(Remote Desktop)
> It is built in to XP so is an easy choice
> From Control Panel - System look on the Remote tab
> Tick the box to use Remote Desktop
> Setup your router to allow access to the RDP port which is 3389
> Now you can connect
> Make sure you use strong passwords and renaming the administrator account
is
> a good idea also
http://www.microsoft.com/windowsxp/using/mobility/getstarted/remoteintro.mspx
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/583.mspx
> Regards
> Mark Dormer
> "Enver A" <ea90@hotmail.com> wrote in message
> news:eazRXARVEHA.3264@TK2MSFTNGP10.phx.gbl...
> > Hey there ppl,
> > I want to connect to my home PC from work. I use ADSL connection both
> > sides.
> > Both modems are Zoom X3. Both external modems. And i am using LAN at
both
> > sides. Can it be possible?
