Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
My remote desktop connection works fine when I connect with a Remote Desktop client. However when I connect with a web based connection I get the following error -- this happened out of the blue after successful use for over 2 years.
Any ideas??? ...
error as follows:
timed out. Please try connecting to the remote computer again." const L_DisconnectIdleTimeout_ErrorMessage = "The remote session was ended because the idle timeout limit was reached. This limit is set by the server administrator or by network policies." const L_DisconnectLogonTimeout_ErrorMessage ="The remote session ended because the total logon time limit was reached. This limit is set by the server administrator or by network policies." const L_ProtocolErrWITHCODE_ErrorMessage = "Client disconnected due to internal protocol error: " const L_LicensingTimeout_ErrorMessage = "A licensing error occurred while the client was attempting to connect (Licensing timed out).Please try connecting to the remote computer again." const L_LicensingNegotFailed_ErrorMessage = "The remote computer disconnected the session because of an error in the licensing protocol.Please try connecting to the remote computer again or contact your server administrator." const L_DisconnectRemoteByServerTool_ErrorMessage = "The remote session to the remote computer was ended by means of an administration tool.Your administrator might have ended your connection." const L_LogoffRemoteByServer_ErrorMessage = "The remote session was disconnected because your session was logged off at the remote computer.Your administrator or another user might have ended your connection." const L_DisconnectByOtherConnection_ErrorMessage = "The remote session was disconnected because another user has connected to the session." const L_ConnectionBroken_ErrorMessage = "The connection to the remote computer was broken. This may have been caused by a network error.Please try connecting to the remote computer again." const L_ServerOutOfMemory_ErrorMessage = "The connection was disconnected because the remote computer is low on memory." const L_LicenseInternal_ErrorMessage = "The remote session was disconnected because there was an internal error in the remote computer's licensing protocol." const L_NoLicenseServer_ErrorMessage = "The remote session was disconnected because there are no Terminal Server License Servers available to provide a license.Please contact the server administrator." const L_NoLicense_ErrorMessage = "The remote session was disconnected because there are no Terminal Server client access licenses available for this computer.Please contact the server administrator." const L_LicenseBadClientMsg_ErrorMessage = "The remote session was disconnected because the remote computer received an invalid licensing message from this computer." const L_LicenseHwidDoesntMatch_ErrorMessage = "The remote session was disconnected because the Terminal Server client access license stored on this computer has been modified." const L_BadClientLicense_ErrorMessage = "The remote session was disconnected because the Terminal Server client access license stored on this computer is in an invalid format." const L_LicenseCantFinishProtocol_ErrorMessage = "The remote session was disconnected because there were network problems during the licensing protocol.Please try connecting to the remote computer again." const L_LicenseClientEndedProtocol_ErrorMessage = "The remote session was disconnected because the client prematurely ended the licensing protocol." const L_LicenseBadClientEncryption_ErrorMessage = "The remote session was disconnected because a licensing message was incorrectly encrypted." const L_CantUpgradeLicense_ErrorMessage = "The remote session was disconnected because the local computer's client access license could not be upgraded or renewed.Please contact the server administrator." const L_LicenseNoRemoteConnections_ErrorMessage = "The remote session was disconnected because the remote computer is not licensed to accept remote connections.Please contact the server administrator." const L_DecompressionFailed_ErrorMessage = "The remote session was disconnected because of a decompression failure at the client side. Please try connecting to the remote computer again." const L_ServerDeniedConnection_ErrorMessage ="The client could not establish a connection to the remote computer.The most likely causes for this error are:1) Remote connections might not be enabled at the remote computer.2) The maximum number of connections was exceeded at the remote computer.3) A network error occurred while establishing the connection." sub window_onload() if not LCase(Navigator.CpuClass) = "x86" then msgbox L_PlatformCheck_ErrorMessage end if if not autoConnect() then Document.all.editServer.Focus end if end sub function autoConnect() Dim sServer Dim iFS, iAutoConnect sServer = getQS ("Server" ) iAutoConnect = getQS ("AutoConnect" ) iFS = getQS ("FS" ) if NOT IsNumeric ( iFS ) then iFS = 0 else iFS = CInt ( iFS ) end if if iAutoConnect <> 1 then autoConnect = false exit function else if iFS < 0 or iFS >= Document.all.comboResolution.options.length then iFS = 0 end if if IsNull ( sServer ) or sServer = "" then sServer = window.location.hostname end if Document.all.comboResolution.selectedIndex = iFS Document.all.Server.value = sServer btnConnect () autoConnect = true end if end function function getQS ( sKey ) Dim iKeyPos, iDelimPos, iEndPos Dim sURL, sRetVal iKeyPos = iDelimPos = iEndPos = 0 sURL = window.location.href if sKey = "" Or Len(sKey) < 1 then getQS = "" exit function end if iKeyPos = InStr ( 1, sURL, sKey ) if iKeyPos = 0 then sRetVal = "" exit function end if iDelimPos = InStr ( iKeyPos, sURL, "=" ) iEndPos = InStr ( iDelimPos, sURL, "&" ) if iEndPos = 0 then sRetVal = Mid ( sURL, iDelimPos + 1 ) else sRetVal = Mid ( sURL, iDelimPos + 1, iEndPos - iDelimPos - 1 ) end if getQS = sRetVal end function sub checkClick if Document.all.Check1.Checked then Document.all.tableLogonInfo.style.display = "" Document.all.editUserName.Disabled = false Document.all.editDomain.Disabled = false else Document.all.tableLogonInfo.style.display = "none" Document.all.editUserName.Disabled = true Document.all.editDomain.Disabled = true end if end sub sub OnControlLoad set Control = Document.getElementById("MsRdpClient" ) if Not Control is Nothing then if Control.readyState = 4 then Document.all.connectButton.disabled = FALSE end if end if end sub sub BtnConnect Dim serverName 'server if not Document.all.Server.value = "" then serverName = Document.all.Server.value else serverName = Document.location.hostname end if serverName = trim(serverName) MsRdpClient.server = serverName 'serverName name text Document.all.srvNameField.innerHtml = serverName 'Username/Domain if Document.all.CheckBoxAutoLogon.checked then MsRdpClient.UserName = Document.all.UserName.Value MsRdpClient.Domain = Document.all.Domain.Value end if 'Resolution MsRdpClient.FullScreen = FALSE select case document.all.comboResolution.value case "1" MsRdpClient.FullScreen = TRUE resWidth = screen.width resHeight = screen.height case "2" resWidth = "640" resHeight = "480" case "3" resWidth = "800" resHeight = "600" case "4" resWidth = "1024" resHeight = "768" case "5" resWidth = "1280" resHeight = "1024" case "6" resWidth = "1600" resHeight = "1200" end select MsRdpClient.DesktopWidth = resWidth MsRdpClient.DesktopHeight = resHeight MsRdpClient.Width = resWidth MsRdpClient.Height = resHeight 'Device redirection options MsRdpClient.AdvancedSettings2.RedirectDrives = FALSE MsRdpClient.AdvancedSettings2.RedirectPrinters = TRUE MsRdpClient.AdvancedSettings2.RedirectPorts = FALSE MsRdpClient.AdvancedSettings2.RedirectSmartCards = FALSE 'FullScreen title MsRdpClient.FullScreenTitle = L_FullScreenTitle_Text & "(" & serverName & " )" 'Display connect region Document.all.loginArea.style.display = "none" Document.all.connectArea.style.display = "block" 'Connect MsRdpClient.Connect end sub -->
Remote Desktop Web Connection
Type the name of the remote computer you want to use, select the screen size for your connection, and then click Connect.
When the connection page opens, you can add it to your Favorites for easy connection to the same computer.
Server:
Size:
Full-screen 640 by 480 800 by 600 1024 by 768 1280 by 1024 1600 by 1200
Send logon information for this connection
Seems like you are having problems accessing the web server on the PC you
are connecting to. Can you access any web pages on the machine you are
trying to control?
Jim Hubbard
Hubbard Software
"jcrompton" <jcrompton@discussions.microsoft.com> wrote in message
news:5BDD1B2E-B73F-4678-A131-01FCFCDEF849@microsoft.com...
over 2 years.
> Any ideas??? ...
> error as follows:
> Server:
> Size:
1200
Yes I can - everything on the server (one being accessed) and the client works normally otherwise. I can even access the "server" machine fine if I use a client application to access it. It only happens when I try to go through the web i.e., http://<ip address>/tsweb to try to access the other machine. I need to do this because sometime when I travel I have to use computers that don;t have the remote desktop application installed.
> trying to control?
> Jim Hubbard
> Hubbard Software
> over 2 years.
> > Any ideas??? ...
> > error as follows:
> > Server:
> > Size:
> 1200
I have addressed this issue the past few days.. What resolution have
you gotten? Check back to your past postings..
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Mon, 21 Jun 2004 15:58:06 -0700, jcrompton
>Any ideas??? ...
>error as follows:
> Server:
>Size:
Have you tried a re-install of tsweb stuff?
news:3EF2EA7D-0AD1-4B36-B706-D85FBF2119B7@microsoft.com...
you
> > trying to control?
> > Jim Hubbard
> > Hubbard Software
the
for
> > over 2 years.
> > > Any ideas??? ...
> > > error as follows:
because
the
internal
error
the
connecting
const
disconnected
was
connecting
"The
memory."
disconnected
was
available
disconnected
this
session
stored on
protocol."
was
const
or
remote
disconnected
connecting
end
getQS
NOT
or
if
if
iKeyPos =
end
else
getQS
then
end
TRUE
"640"
resHeight
title
"none"
screen
easy
> > > Server:
> > > Size:
> > 1200
I sure did -- I even tried making sure that I had manually deleted any remaining folders like the inet folder in the root of c drive etc. Any other ideas?
> you
> > > trying to control?
> > > Jim Hubbard
> > > Hubbard Software
> the
> for
> > > over 2 years.
> > > > Any ideas??? ...
> > > > error as follows:
> because
> the
> internal
> error
> the
> connecting
> const
> disconnected
> was
> connecting
> "The
> memory."
> disconnected
> was
> available
> disconnected
> this
> session
> stored on
> protocol."
> was
> const
> or
> remote
> disconnected
> connecting
> end
> getQS
> NOT
> or
> if
> if
> iKeyPos =
> end
> else
> getQS
> then
> end
> TRUE
> "640"
> resHeight
> title
> "none"
> screen
> easy
> > > > Server:
> > > > Size:
> > > 1200
hmmmmm.......let me think about it and I'll get back with you tomorrow
night.....
news:99B2805A-7E2E-4E19-81A2-DB6B57355E30@microsoft.com...
other ideas?
client
I
other
PC
> > you
are
> > > > trying to control?
> > > > Jim Hubbard
> > > > Hubbard Software
Remote
get
> > the
use
> > for
> > > > over 2 years.
> > > > > Any ideas??? ...
> > > > > error as follows:
const
> > because
because
> > the
> > internal
licensing
> > error
disconnected
> > the
> > connecting
> > const
the
> > disconnected
const
const
computer
> > was
> > connecting
> > "The
> > memory."
> > disconnected
licensing
session
> > was
> > available
because
this
> > disconnected
from
> > this
> > session
> > stored on
client
const
licensing
> > protocol."
session
> > was
> > const
disconnected
upgraded
> > or
> > remote
> > disconnected
> > connecting
computer.The
not be
was
if
> > end
> > getQS
if
> > NOT
< 0
> > or
if
> > if
end
> > if
Dim
> > iKeyPos =
function
> > end
iDelimPos,
1 )
> > else
if
> > getQS
> > then
then if
FALSE
> > end
text
> > TRUE
> > "640"
"4"
resHeight
> > resHeight
FALSE
> > title
serverName
> > "none"
> > screen
for
> > easy
> > > > > Server:
> > > > > Size:
1600 by
> > > > 1200
Thanks
> night.....
> other ideas?
> client
> I
> other
> PC
> > > you
> are
> > > > > trying to control?
> > > > > Jim Hubbard
> > > > > Hubbard Software
> Remote
> get
> > > the
> use
> > > for
> > > > > over 2 years.
> > > > > > Any ideas??? ...
> > > > > > error as follows:
> const
> > > because
> because
> > > the
> > > internal
> licensing
> > > error
> disconnected
> > > the
> > > connecting
> > > const
> the
> > > disconnected
> const
> const
> computer
> > > was
> > > connecting
> > > "The
> > > memory."
> > > disconnected
> licensing
> session
> > > was
> > > available
> because
> this
> > > disconnected
> from
> > > this
> > > session
> > > stored on
> client
> const
> licensing
> > > protocol."
> session
> > > was
> > > const
> disconnected
> upgraded
> > > or
> > > remote
> > > disconnected
> > > connecting
> computer.The
> not be
> was
> if
> > > end
> > > getQS
> if
> > > NOT
> < 0
> > > or
> if
> > > if
> end
> > > if
> Dim
> > > iKeyPos =
> function
> > > end
> iDelimPos,
> 1 )
> > > else
> if
> > > getQS
> > > then
> then if
> FALSE
> > > end
> text
> > > TRUE
> > > "640"
> "4"
> resHeight
> > > resHeight
> FALSE
> > > title
> serverName
> > > "none"
> > > screen
> for
> > > easy
> > > > > > Server:
> > > > > > Size:
> 1600 by
> > > > > 1200
My apologies -- but I could not find where you had addressed this issue anywhere. Itried the fix that was listed for the Sasser worm issue but this is a whole different issue in that the Remote desktop connection still works as long as you use the client but I also need to be able to connect via the web based tsweb app, which is what suddenly quit working. Any further guidance?
> >Any ideas??? ...
> >error as follows:
> > Server:
> >Size:
I just found an interesting thing -- I set up the web client to connect through a different port on my router instead of the default port , 80. When I went to the page http://<ip address>
ort/tsweb I then got a clean page without all of the errors! However when I tried to connect "full screen" I got an error on page error in the bottom left corner of my browser. However if I connected at anyhting less than "full screen" it worked like a charm.
Strange behavior -- any ideas?? I hope others get soemthing out of this
> night.....
> other ideas?
> client
> I
> other
> PC
> > > you
> are
> > > > > trying to control?
> > > > > Jim Hubbard
> > > > > Hubbard Software
> Remote
> get
> > > the
> use
> > > for
> > > > > over 2 years.
> > > > > > Any ideas??? ...
> > > > > > error as follows:
> const
> > > because
> because
> > > the
> > > internal
> licensing
> > > error
> disconnected
> > > the
> > > connecting
> > > const
> the
> > > disconnected
> const
> const
> computer
> > > was
> > > connecting
> > > "The
> > > memory."
> > > disconnected
> licensing
> session
> > > was
> > > available
> because
> this
> > > disconnected
> from
> > > this
> > > session
> > > stored on
> client
> const
> licensing
> > > protocol."
> session
> > > was
> > > const
> disconnected
> upgraded
> > > or
> > > remote
> > > disconnected
> > > connecting
> computer.The
> not be
> was
> if
> > > end
> > > getQS
> if
> > > NOT
> < 0
> > > or
> if
> > > if
> end
> > > if
> Dim
> > > iKeyPos =
> function
> > > end
> iDelimPos,
> 1 )
> > > else
> if
> > > getQS
> > > then
> then if
> FALSE
> > > end
> text
> > > TRUE
> > > "640"
> "4"
> resHeight
> > > resHeight
> FALSE
> > > title
> serverName
> > > "none"
> > > screen
> for
> > > easy
> > > > > > Server:
> > > > > > Size:
> 1600 by
> > > > > 1200
> >Any ideas??? ...
> >error as follows:
> > Server:
> >Size:
Is ASP enabled on your IIS?
news:658879A6-EAC9-4F6D-AB71-75B1AB741363@microsoft.com...
> > night.....
> > other ideas?
> > client
fine if
> > I
go
the
> > other
use
the
> > PC
> > > > you
you
> > are
> > > > > > trying to control?
> > > > > > Jim Hubbard
> > > > > > Hubbard Software
message
> > Remote
connection I
> > get
> > > > the
successful
> > use
> > > > for
> > > > > > over 2 years.
> > > > > > > Any ideas??? ...
> > > > > > > error as follows:
again."
> > const
ended
> > > > because
server
> > because
> > > > the
server
> > > > internal
> > licensing
> > > > error
timed
> > disconnected
> > > > the
> > > > connecting
administrator."
> > > > const
session to
> > the
tool.Your
> > > > disconnected
> > const
was
> > const
> > computer
> > > > was
> > > > connecting
> > > > "The
on
> > > > memory."
> > > > disconnected
> > licensing
> > session
> > > > was
Servers
> > > > available
const
> > because
for
> > this
> > > > disconnected
message
> > from
> > > > this
remote
> > > > session
license
> > > > stored on
> > client
> > const
was
> > licensing
const
was
> > > > protocol."
> > session
> > > > was
encrypted."
> > > > const
> > disconnected
> > upgraded
> > > > or
was
accept
> > > > remote
> > > > disconnected
try
> > > > connecting
> > computer.The
might
> > not be
connections
> > was
while
end
> > if
> > > > end
sServer
> > > > getQS
("FS" )
> > if
> > > > NOT
iFS
> > < 0
> > > > or
end
> > if
> > > > if
true
> > end
> > > > if
iEndPos
> > Dim
if
> > > > iKeyPos =
> > function
> > > > end
> > iDelimPos,
> > 1 )
> > > > else
end
> > if
> > > > getQS
> > > > then
> > then if
> > FALSE
> > > > end
name
> > text
'Username/Domain if
> > > > TRUE
resWidth
> > > > "640"
case
> > "4"
> > resHeight
> > > > resHeight
'Device
> > FALSE
'FullScreen
> > > > title
> > serverName
> > > > "none"
the
> > > > screen
Favorites
> > for
> > > > easy
> > > > > > > Server:
> > > > > > > Size:
> > 1600 by
> > > > > > 1200
Not totally sure of all the steps that I need to carry out to enable this or to be sure that it is enabled. I looked it up but it was a bit confusing!
> > > night.....
> > > other ideas?
> > > client
> fine if
> > > I
> go
> the
> > > other
> use
> the
> > > PC
> > > > > you
> you
> > > are
> > > > > > > trying to control?
> > > > > > > Jim Hubbard
> > > > > > > Hubbard Software
> message
> > > Remote
> connection I
> > > get
> > > > > the
> successful
> > > use
> > > > > for
> > > > > > > over 2 years.
> > > > > > > > Any ideas??? ...
> > > > > > > > error as follows:
> again."
> > > const
> ended
> > > > > because
> server
> > > because
> > > > > the
> server
> > > > > internal
> > > licensing
> > > > > error
> timed
> > > disconnected
> > > > > the
> > > > > connecting
> administrator."
> > > > > const
> session to
> > > the
> tool.Your
> > > > > disconnected
> > > const
> was
> > > const
> > > computer
> > > > > was
> > > > > connecting
> > > > > "The
> on
> > > > > memory."
> > > > > disconnected
> > > licensing
> > > session
> > > > > was
> Servers
> > > > > available
> const
> > > because
> for
> > > this
> > > > > disconnected
> message
> > > from
> > > > > this
> remote
> > > > > session
> license
> > > > > stored on
> > > client
> > > const
> was
> > > licensing
> const
> was
> > > > > protocol."
> > > session
> > > > > was
> encrypted."
> > > > > const
> > > disconnected
> > > upgraded
> > > > > or
> was
> accept
> > > > > remote
> > > > > disconnected
> try
> > > > > connecting
> > > computer.The
> might
> > > not be
> connections
> > > was
> while
> end
> > > if
> > > > > end
> sServer
> > > > > getQS
> ("FS" )
> > > if
> > > > > NOT
> iFS
> > > < 0
> > > > > or
> end
> > > if
> > > > > if
> true
> > > end
> > > > > if
> iEndPos
> > > Dim
> if
> > > > > iKeyPos =
> > > function
> > > > > end
> > > iDelimPos,
> > > 1 )
> > > > > else
> end
> > > if
> > > > > getQS
> > > > > then
> > > then if
> > > FALSE
> > > > > end
> name
> > > text
> 'Username/Domain if
> > > > > TRUE
> resWidth
> > > > > "640"
> case
> > > "4"
> > > resHeight
> > > > > resHeight
> 'Device
> > > FALSE
> 'FullScreen
> > > > > title
> > > serverName
> > > > > "none"
> the
> > > > > screen
> Favorites
> > > for
> > > > > easy
> > > > > > > > Server:
> > > > > > > > Size:
> > > 1600 by
> > > > > > > 1200
-Installing Asp is easy ...
1.. In Control Panel, click Add/Remove Programs.
2.. Click Add/Remove Windows Components, and then select the Internet
Information Services check box.
3.. In the Windows Component Wizard, click Next, and follow the on-screen
instructions.
news:ED7CB647-6A70-45BD-836B-FA06141DC0F8@microsoft.com...
connect
clean
this
tomorrow
> > > > night.....
any
Any
> > > > other ideas?
message
the
> > > > client
> > fine if
> > > > I
try to
> > go
access
> > the
> > > > other
to
> > use
installed.
on
> > the
> > > > PC
> > > > > > you
machine
> > you
> > > > are
> > > > > > > > trying to control?
> > > > > > > > Jim Hubbard
> > > > > > > > Hubbard Software
> > message
with a
> > > > Remote
> > connection I
> > > > get
> > > > > > the
> > successful
> > > > use
> > > > > > for
> > > > > > > > over 2 years.
> > > > > > > > > Any ideas??? ...
> > > > > > > > > error as follows:
> > again."
> > > > const
was
> > ended
> > > > > > because
> > server
ended
> > > > because
> > > > > > the
> > server
due to
> > > > > > internal
> > > > licensing
> > > > > > error
(Licensing
> > timed
const
> > > > disconnected
> > > > > > the
try
> > > > > > connecting
> > administrator."
> > > > > > const
> > session to
> > > > the
> > tool.Your
was
> > > > > > disconnected
computer.Your
connection."
> > > > const
session
> > was
session."
> > > > const
remote
> > > > computer
> > > > > > was
try
> > > > > > connecting
> > > > > > "The
low
> > on
> > > > > > memory."
was
> > > > > > disconnected
> > > > licensing
remote
> > > > session
> > > > > > was
> > Servers
> > > > > > available
administrator."
> > const
disconnected
> > > > because
available
> > for
> > > > this
> > > > > > disconnected
> > message
> > > > from
> > > > > > this
"The
> > remote
> > > > > > session
> > license
> > > > > > stored on
Server
> > > > client
format."
> > > > const
session
> > was
> > > > licensing
again."
> > const
session
> > was
licensing
> > > > > > protocol."
remote
> > > > session
> > > > > > was
> > encrypted."
> > > > > > const
> > > > disconnected
be
> > > > upgraded
> > > > > > or
session
> > was
> > accept
> > > > > > remote
> > > > > > disconnected
Please
> > try
> > > > > > connecting
> > > > computer.The
> > might
> > > > not be
> > connections
> > > > was
> > while
> > end
> > > > if
> > > > > > end
> > sServer
> > > > > > getQS
> > ("FS" )
> > > > if
> > > > > > NOT
if if
else if
> > iFS
> > > > < 0
> > > > > > or
= 0
> > end
> > > > if
> > > > > > if
autoConnect =
> > true
> > > > end
> > > > > > if
> > iEndPos
> > > > Dim
end
> > if
> > > > > > iKeyPos =
exit
> > > > function
> > > > > > end
> > > > iDelimPos,
iDelimPos
> > > > 1 )
> > > > > > else
1 )
> > end
> > > > if
> > > > > > getQS
> > > > > > then
"none"
Nothing
> > > > then if
> > > > FALSE
> > > > > > end
not
serverName =
> > name
> > > > text
> > 'Username/Domain if
case
> > > > > > TRUE
> > resWidth
> > > > > > "640"
"600"
> > case
> > > > "4"
"1280"
> > > > resHeight
select
> > > > > > resHeight
> > 'Device
> > > > > > > > redirection options
> > > > FALSE
> > 'FullScreen
> > > > > > title
> > > > serverName
> > > > > > "none"
select
> > the
> > > > > > screen
> > Favorites
> > > > for
> > > > > > easy
> > > > > > > > > Server:
> > > > > > > > > Size:
1024
> > > > 1600 by
> > > > > > > > 1200
Maybe a proxy, perhaps?
On Tue, 22 Jun 2004 20:58:01 -0700, jcrompton
>> >Any ideas??? ...
>> >error as follows:
>> > Server:
>> >Size:
Sorry I didn;t understand exactly what asp was. It was infact already installed!
> instructions.
> connect
> clean
> this
> tomorrow
> > > > > night.....
> any
> Any
> > > > > other ideas?
> message
> the
> > > > > client
> > > fine if
> > > > > I
> try to
> > > go
> access
> > > the
> > > > > other
> to
> > > use
> installed.
> on
> > > the
> > > > > PC
> > > > > > > you
> machine
> > > you
> > > > > are
> > > > > > > > > trying to control?
> > > > > > > > > Jim Hubbard
> > > > > > > > > Hubbard Software
> > > message
> with a
> > > > > Remote
> > > connection I
> > > > > get
> > > > > > > the
> > > successful
> > > > > use
> > > > > > > for
> > > > > > > > > over 2 years.
> > > > > > > > > > Any ideas??? ...
> > > > > > > > > > error as follows:
> > > again."
> > > > > const
> was
> > > ended
> > > > > > > because
> > > server
> ended
> > > > > because
> > > > > > > the
> > > server
> due to
> > > > > > > internal
> > > > > licensing
> > > > > > > error
> (Licensing
> > > timed
> const
> > > > > disconnected
> > > > > > > the
> try
> > > > > > > connecting
> > > administrator."
> > > > > > > const
> > > session to
> > > > > the
> > > tool.Your
> was
> > > > > > > disconnected
> computer.Your
> connection."
> > > > > const
> session
> > > was
> session."
> > > > > const
> remote
> > > > > computer
> > > > > > > was
> try
> > > > > > > connecting
> > > > > > > "The
> low
> > > on
> > > > > > > memory."
> was
> > > > > > > disconnected
> > > > > licensing
> remote
> > > > > session
> > > > > > > was
> > > Servers
> > > > > > > available
> administrator."
> > > const
> disconnected
> > > > > because
> available
> > > for
> > > > > this
> > > > > > > disconnected
> > > message
> > > > > from
> > > > > > > this
> "The
> > > remote
> > > > > > > session
> > > license
> > > > > > > stored on
> Server
> > > > > client
> format."
> > > > > const
> session
> > > was
> > > > > licensing
> again."
> > > const
> session
> > > was
> licensing
> > > > > > > protocol."
> remote
> > > > > session
> > > > > > > was
> > > encrypted."
> > > > > > > const
> > > > > disconnected
> be
> > > > > upgraded
> > > > > > > or
> session
> > > was
> > > accept
> > > > > > > remote
> > > > > > > disconnected
> Please
> > > try
> > > > > > > connecting
> > > > > computer.The
> > > might
> > > > > not be
> > > connections
> > > > > was
> > > while
> > > end
> > > > > if
> > > > > > > end
> > > sServer
> > > > > > > getQS
> > > ("FS" )
> > > > > if
> > > > > > > NOT
> if if
> else if
> > > iFS
> > > > > < 0
> > > > > > > or
> = 0
> > > end
> > > > > if
> > > > > > > if
> autoConnect =
> > > true
> > > > > end
> > > > > > > if
> > > iEndPos
> > > > > Dim
> end
> > > if
> > > > > > > iKeyPos =
> exit
> > > > > function
> > > > > > > end
> > > > > iDelimPos,
> iDelimPos
> > > > > 1 )
> > > > > > > else
> 1 )
> > > end
> > > > > if
> > > > > > > getQS
> > > > > > > then
> "none"
> Nothing
> > > > > then if
> > > > > FALSE
> > > > > > > end
> not
> serverName =
> > > name
> > > > > text
> > > 'Username/Domain if
> case
> > > > > > > TRUE
> > > resWidth
> > > > > > > "640"
> "600"
> > > case
> > > > > "4"
> "1280"
> > > > > resHeight
> select
> > > > > > > resHeight
> > > 'Device
> > > > > > > > > redirection options
> > > > > FALSE
> > > 'FullScreen
> > > > > > > title
> > > > > serverName
> > > > > > > "none"
> select
> > > the
> > > > > > > screen
> > > Favorites
> > > > > for
> > > > > > > easy
> > > > > > > > > > Server:
> > > > > > > > > > Size:
> 1024
> > > > > 1600 by
> > > > > > > > > 1200
Still have been unable to resolve this issue. Do you have
any other ideas? Is there a place this has been addressed
before?
>-----Original Message-----
benefit
not
resolution have
benefit
may not
>>> >Any ideas??? ...
>>> >error as follows:
sServer =
= "600"
redirection options
Connect.
>>> > Server:
>>> >Size:
Since a couple of days I keep getting the same problem. Trying to connect via TSWeb Internet Explorer gives the following error:
A runtime error has occurred. Do you wish to debug?
Line: 303
Error: Type mismatch: 'OnControlLoad'.
Clicking "no" to this debug-question shows part of the default.html-script in InterNet Explorer (as jcromptom quoted: "timed out. Please (...) connection to the same computer" ).
Keep getting this error while connecting from another computer over the internet by http://ip
ort/tsweb as well as during connecting directly from my own computer by http://hostname
ort/tsweb.
At the same time, the IIS Service Default WebPage (INetPub/wwwroot/iisstart.asp) has started giving script errors.
Before, both scripts worked out fine. Problems occurred out of the blue.
It seems to me the scripts suddenly are not run properly, maybe as a result of some lately installed security patch. Don't know for sure if that's it, and certainlay cannot find out which patch would be the problem .......
any suggestions?
> Any ideas??? ...
> error as follows:
> Server:
> Size:
Problem found ...
Tackled the problem by disabling all running programs (virus scanner, third-party fire-wall, FTP server and the like). Then the IIS Web Service / Remote Desktop worked perfectly as ever before. By starting up background processes again, it appears that - at least in my case - the latest version of ZoneAlarm (free edition, version 5.0590) is interfering with the Win XP IIS Services.
Checked out their site, and the Zone Alarm team is aware of the problem: http://forums.zonelabs.com/zonelab [...] e.id=5395.
Reverting to a previous version resolves the problem.
I hope this will help some others as well.
Regards,
JpH.
> Line: 303
ort/tsweb.
> any suggestions?
> > Any ideas??? ...
> > error as follows:
> > Server:
> > Size:
You don't have the ActiveX control installed...
From a past posting:
This most likely indicated a problem with the TS ActiveX control . Go
in to IE Options, and look at the installed Objects (either by using
Tools->Internet Options::Settings->View Objects, or by opening
Explorer and navigating to C:\Windows\Downloaded Program Files). You
should see an entry called "Microsoft Terminal Services Control
(redist) (or Microsoft RDC Client Control". If it isn't listed, then
the problem is it isn't installed! If it is installed, try removing it
and letting it reinstall. If this is an XP machine, you can always use
Start->Programs->Accessories->Communication->Remote Desktop
Connection,which in my opinion works a lot better....
On Tue, 29 Jun 2004 15:00:01 -0700, JpH
>Line: 303
ort/tsweb.
>any suggestions?
>> Any ideas??? ...
>> error as follows:
>> Server:
>> Size:
Jeffrey,
Thank you very much for your quick reply. ActiveX control is not the problem though.
As i said earlier, the problem is due to ZoneAlarm firewall upgrade to version 5. Today I reverted to version 4.5 and everything works fine again.
Just for the record - Indeed the Remote Control Client application works better, however sometimes I need to connect to my computer from a work station on which I don't have setup permissions. In that case, TSWeb is a good alternative.
Thanks for your help anyway!
Regards,
JpH.
> >Line: 303
ort/tsweb.
> >any suggestions?
> >> Any ideas??? ...
> >> error as follows:
> >> Server:
> >> Size:
I guess ZA was filtering the ActiveX control.. Weird... (but then I
don't use ZoneAlarm)
In the other case, you may find instances when you won't be able to
use the web client if it has not been installed prior or depending on
the ActiveX security settings...
On Wed, 30 Jun 2004 07:34:01 -0700, JpH
>Jeffrey,
>Regards,
>JpH.
>> >Line: 303
ort/tsweb.
>> >any suggestions?
>> >> Any ideas??? ...
>> >> error as follows:
>> >> Server:
>> >> Size:
There are 629 identified and unidentified users. To see the list of identified users, Click here.
