Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
Hi,
I am trying to set up the remote desktop web connection with Windows XP Professional. I went on the Microsoft web site and found a page that told me how to install the web host part of it. Can you use it without a web server and just make your computer a web server??? I have a linksys wireless and wired router and cable internet through Earthlink. I am also using a Mcafee firewall.
I would appreciate some help on this matter; I am a beginner so it would be helpful if the instructions were plain, specific and simple.
You already have a webserver (IIS) in WinXP. Just install the TSWeb app and
it should be good to go...
Kevin wrote:
> Hi,
> Thanks,
> Kevin
I was looking in the directions and it said to type in for the address, http://"server name"/tsweb. Is the server name the name of my computer, the ip address of my computer, the ip address of my router, then the port number of my computer or what???
Thanks
> Kevin wrote:
> > Hi,
> > Thanks,
> > Kevin
refering to the second post. Is there an actual app. that you can use or is it like a service? Also how do you activate it??????????
Thanks
> Thanks
> > Kevin wrote:
> > > Hi,
> > > Thanks,
> > > Kevin
Your "server name" is your public IP address (or a dynamic DNS name,
if you have set one up at http://www.dyndns.org or one of the other
dynamic DNS providers).
You only specify the port number if it is different than standard, in
which case it is http://servernameort/tsweb (note that the port
reference refers to the IIS port, not the Remote Desktop port). If
you want to respecify the Remote Desktop port, you need to use a
slightly modified version of the remote desktop page to do this...
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
On Thu, 24 Jun 2004 08:23:02 -0700, "Kevin"
>Thanks
>> Kevin wrote:
>> > Hi,
>> > Thanks,
>> > Kevin
On Thu, 24 Jun 2004 08:26:02 -0700, "Kevin"
>Thanks
>> Thanks
>> > Kevin wrote:
>> > > Hi,
>> > > Thanks,
>> > > Kevin
"Jeffrey Randow (MVP)" <jeffreyr-support@remotenetworktechnology.com> wrote
in message news:crtmd0phvhl54gh4kf746an1fsuvpcsb2l@4ax.com...
> Jeffrey Randow (Windows Networking & Smart Display MVP)
> Remote Networking Technology Support Site -
> http://www.remotenetworktechnology.com > Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone >
> >Thanks
and
> >> Kevin wrote:
> >> > Hi,
> >> > Thanks,
> >> > Kevin
