Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Try to have someone else open up this web page.. Either your browser
is not parsing the script commands or the IIS install is seriosly
hosed...
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone -
http://www.microsoft.com/windowsxp/expertzone
On Sun, 04 Jul 2004 03:47:56 GMT, skip <dan@ydeletethis.com> wrote:
>Jeff,
> I uninstalled both the IIS and the RDC, rebooted, deleted any left
>over files, rebooted and then reloaded the IIS and remote destop,
>rebooted.
>I then ran a program "tswebsetup.exe". Rebooted. I then opened the
>browser window and enter 192.168.xxx.xxx and got the following error
>and it was repeated through the whole page.
> "as timed out. Please try connecting to the remote computer
>again." const L_DisconnectIdleTimeout_ErrorMessage = "The remote
>session was ended because the idle timeout limit was reached. This
>limit is set by the server administrator or by network policies."
>const L_DisconnectLogonTimeout_ErrorMessage ="The remote session ended
>because the total logon time limit was reached. This limit is set by
>the server administrator or by network policies." const
>L_ProtocolErrWITHCODE_ErrorMessage = "Client disconnected due to
>internal protocol error: " const L_LicensingTimeout_ErrorMessage = "A
>licensing error occurred while the client was attempting to connect
>(Licensing timed out).Please try connecting to the remote computer
>again." const L_LicensingNegotFailed_ErrorMessage = "The remote
>computer disconnected the session because of an error in the licensing
>protocol.Please try connecting to the remote computer again or contact
>your server administrator." const
>L_DisconnectRemoteByServerTool_ErrorMessage = "The remote session to
>the remote computer was ended by means of an administration tool.Your
>administrator might have ended your connection." const
>L_LogoffRemoteByServer_ErrorMessage = "The remote session was
>disconnected because your session was logged off at the remote
>computer.Your administrator or another user might have ended your
>connection." const "
>If I enter the 127.0.0.1/tsweb I get the same error. If I enter
>12.0.0.1/tsweb I received same error.
>I really hate to be a bother, but I am not starting to run against a
>restricted time and have to get this web to work as soon as possible.
>Any other help you can give me would be greatly appreciated.
>Dan (Still going in circles)
>On Tue, 29 Jun 2004 20:25:08 -0500, "Jeffrey Randow (MVP)"
><jeffreyr-support@remotenetworktechnology.com> wrote:
>>Yep.. Actually, remove it then install it again...
>>On Tue, 29 Jun 2004 03:06:22 GMT, skip <dan@ydeletethis.com> wrote:
>>>Jeff,
>>> I have IIS installed but I guess it isn't work right, to reinstall it
>>>all I have to do is just run the install program again. Right?
>>>On Sun, 27 Jun 2004 20:09:39 -0500, "Jeffrey Randow (MVP)"
>>>>If you don't get a page when using http://localhost, then you do not
>>>>have IIS configured properly...
>>>>On Sun, 27 Jun 2004 23:37:52 GMT, skip <dan@ydeletethis.com> wrote:
>>>>>Jeff,
>>>>>I know this isn't my thread, but I tried what you had suggested and I
>>>>>only get the page not found.
>>>>>Any ideas?
>>>>>Thanks.
>>>>>Dan
>>>>>On Sat, 26 Jun 2004 18:35:01 -0700, Super Sam <Super
>>>>>Sam@discussions.microsoft.com> wrote:
>>>>>>Okay, but I don't know what a localhost is. What is it?
>>>>>>"Jeffrey Randow (MVP)" wrote:
>>>>>>> Try accessing it locally (i.e., http://localhost
ort/tsweb). Do you
>>>>>>> see it there? If so, then the problem is probably with your ISP...
>>>>>>> On Sat, 26 Jun 2004 06:29:02 -0700, "Super Sam"
>>>>>>> <supersammyfluff@msn.com> wrote:
>>>>>>> >I can't seem to access my computer using the web
>>>>>>> >connection method - I can access my computer from other
>>>>>>> >computers on the network by using the non-web version but
>>>>>>> >I can't access it from any computer using the web version.
>>>>>>> >I go to the thing you're meant to go to
>>>>>>> >(http://ipaddress
ort/tsweb) but I get the message that
>>>>>>> >I'm now authorized to view this page. Anybody know how to
>>>>>>> >fix this problem?
