Setting up Remote Desktop Web Connection
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I am trying to set up my remote desktop web connection. I have it partially working. On the local network or accross the internet using a IE 6.0, I can can connect to  ort/tsweb" rel="nofollow" target="_blank">http://x.x.x.x:p ort/tsweb and get the main screen. However when I use a computer name, IP address or nothing in the Server field and click on connect. I get redirected to a blank page that has a box outlined in it. Within the box there is a small paper icon with a red X in it. At the bottom left hand corner of the page on the outside of the box states "You are logged in to" Can anyone please help me so I access my PC via Remote Desktop Web Connection?
Did you get a popup window asking you to install an ActiveX control?
If so, make sure you allow it to be installed..
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Thu, 1 Jul 2004 02:53:01 -0700, "Keith K" <Keith
No, I did not. A collegue of mine shares the same PC and he is able to connect to his w2k box using remote web desktop. I have a setting that is incorrect but I am not sure where to look. Thank you for responding
> responding
He can't be connectingto a Win2k box using remote desktop - W2k doesn't have
that option. Was that a typo?
Related ressources
It was 2003 server or 2000 server, i am not sure. I know it is not winXP Pro
> > responding
> winXP Pro
Ah - OK, I typed too fast anyway as there is terminal services for Win2k
server, not for workstation.
>>> you for responding
>> doesn't have that option. Was that a typo?
>>>> control? If so, make sure you allow it to be installed..
Are you an administrator? Depending on the settings of your computer
and/or domain, you may not be able to install it without Admin
priveleges.
On Fri, 2 Jul 2004 01:49:01 -0700, "Keith K" <Keith
Ask the community
