Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Help! No Audio When Printing to Video
Forum Graphic & Displays : TV/Video Cards - Help! No Audio When Printing to Video
Archived from groups: rec.video.desktop (More info?)
I am really depressed. I have spent about 6 months editing 7 hours of
Amazonian jungle footage down to a 1 hour production and I can not get any
audio when I attempt to print back to my Sony dv camcorder.
Here are the vitals:
Cinestream 3.1
Windows 2000 Professional
Pentium III running at 498 MHz (I know it is slow by today's standards, but
when Cinestream was released it easily met the system requirements)
640 MB of RAM
Maxtor 7200RPM 250GB internal hard drive
Adaptec AFW-4300 FireWire Card
Yamaha DS1x sound card.
Sony TRV120 Digital 8 Camcorder.
DirectX 9.0
Quicktime 5.0 (the highest version Cinestream supports)
No background TSRs running.
Here is what I have tried and double-checked:
1) The audio program track is active and I can hear audio from the project
through my sound card in Cinestream.
2) I have swapped the FireWire card between the Adaptec and the Lynx card
that came with Cinestream.
3) I have tested the connection to my camcorder using DVTester. It reports
no problems and I can control the deck remotely through the software.
4) I have tried rendering the audio in both 48 and 44.1 kHz.
5) I have downloaded from Microsoft all the updates to Windows 2000.
6) I have tried Quicktime 4.0 (the version that came with program).
I am at my wits end and I can not contact the manufacturer because it is a
legacy product and they no longer offer support.
Any help would be appreciated. Thanks.
Btw, this is a hobby, not a profession, hence the outdated hardware.
Paul
Sponsored Links
If you can get the audio out on a file, the two can be combined on another
system.
What options do you have?
"Paul M Rothenberg" <paulmroth@yahoo.com> wrote in message
news:Spidnb-4BroqKxbcRVn-pA@comcast.com...
> Cinestream 3.1
but
> 640 MB of RAM
> DirectX 9.0
> Paul
Reply to Anonymous
- 0 +
Cinestream. Oh, man its been years......
Now, you will already have seperate Mov and Wav files in your render folder.
So, because of this, you certainly have the source material and could use it
in another app if you needed.
You say this was happening before you swapped to the Lynx card? (Don't have
any experience with that, always used straight firewire with Cinestream. Can
you render your project to a selfcontained MOV file and get both vid and
sound with quicktime. (Good your using the older version. I know that QT6
and CS don't play well.)
> Cinestream 3.1
but
> 640 MB of RAM
> DirectX 9.0
> Paul
Reply to rs
I rendered a small section of my timeline and saved it to a self contained
..mov file. Guess what? No audio. When I play the timeline in Cinestream I
can hear the audio. I then opened up the Sound and Audio Devices control
panel and clicked on the Audio tab. The Sound playback, Sound recording and
MIDI music playback device selections are all grayed out. I have a dual
boot system (XP & 2000) and in XP all of the devices are normal.
Any ideas on how I can go about fixing this? It seems this may be the root
of my problem.
Paul
"RS" <idontthinkso@mail.com> wrote in message
news:418bd00c$1_3@newspeer2.tds.net...
folder.
it
have
Can
any
> > Cinestream 3.1
> but
> > 640 MB of RAM
> > DirectX 9.0
project
card
reports
a
> > Paul
Reply to Anonymous
>Cinestream 3.1
>640 MB of RAM
>DirectX 9.0
>Paul
Note that most DV camcorders will not record audio that is other than:
48 kHz
16 bits
stereo
Don't know if this is your problem, but it certainly could be.
webpa
Reply to Anonymous
I would worry about that after you back up the material.
It sounds as Cinestream has perhaps replaced the driver with their own.
Or, there could be a lock problem.
Open Device Manager and check that the driver is enabled.
If it's enabled, but not working, deleting and reinstalling the driver may
solve this problem.
However, this may interfere with the Cinestream app.
The first priority is to back up the material.
Burn the wav files to a CD, and write several tapes of the video.
news:Sdudnf0tzZK6bBbcRVn-sA@comcast.com...
and
root
> of my problem.
> Paul
> folder.
use
> it
> have
> Can
QT6
> any
> > > Cinestream 3.1
standards,
> > but
> > > 640 MB of RAM
> > > DirectX 9.0
> project
> card
> reports
is
> a
> > > Paul
Reply to Anonymous
There are 533 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
