Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > XP SP2 and dv capture problems
Forum Graphic & Displays : TV/Video Cards - XP SP2 and dv capture problems
Archived from groups: rec.video.desktop (More info?)
Hi
I've been having major headaches with dv capture recently and came to
the conclusion that SP2 was the culprit - it had been working fine pre
applying the pack. The capture window in Premiere 6.5 kept 'losing'
the capture driver. After a restart it would sometimes work OK once,
then lose it - or sometimes not at all. Windows movie maker had the
same problem except that it would never capture at all (I believe
Premiere uses the standard windows device capture software, so this
makes sense). I did try turning off DEP, but this made no difference.
Remove SP2 - problem gone.
However I would prefer to have sp2 applied - has anyone else had and
cured this type of capture issue?
Regards
TP
Sponsored Links
On 8 Nov 2004 00:27:32 -0800, timothy.pollard@btinternet.com (Tim
Pollard) wrote:
>Hi
>Regards
>TP
switch off the firewall on the ieee1394 connection.
in fact switch the firewall off while video editing full stop.
Gary MacKenzie
Audio Visual Technician / Video Editor
Reply to Anonymous
There are 646 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
