Archived from groups: microsoft.public.windows.networking.wireless (More info?)
We have just migrated 600+ machines to SP2. Needless to say before we
started on this we carried out *extensive* testing of our systems...and
everything passed. A week later we are finding that we are having huge
problems connecting a specific machine/WLAN card combination to our WLAN.
These machines were used on the WLAN for over a year in SP1 without problems
and given the number of other posts it seems SP2 is the issue:
Symptoms: Machines associate but never get and IP lease. The access point is
quite happy and reports no errors. The machines sit there saying 'Acquiring
network address' until eventually they time out.
Configuration: Toshiba Satellite 1800 + Toshiba mini PIC Wireless LAN card.
AP: Cisco 1200/350
Setup: Static Open WEP OR PEAP-TLS
We get the same results for both access points and both types of
authentication unless we turn off encryption - then everything is fine. But
of course no encryption on the WLAN is a non starter.
Other machine combinations:
IBM T40 + IBM 802.11b
IBM T40 + IBM 802.11a/b/g
Tosh Sat 1800 + Atheros 802.11a/b/g
all work fine.
So it seems to be a specific combination of SP2 + THIS card + encryption.
Needless to say we have all the latest drivers on everything. We have spent
2 days on this and got nowhere. Most frustrating is that when we tested this
combination of hardware prior to the SP2 rollout it worked fine. In fact we
have 2 of the 62 machines in the combinations that *CAN* connect to the WLAN
after Sp2....which is even more frustrating......and if we re-image a
machine that cant connect down to SP1...it immediately connects to the WLAN.
So it seems that SP2 plus specific WLAN hardware combinations is
unpredicatable. Can anyone give any times as to where we can even start to
trouble shoot this issue.
Regards
Al Blake, Canberra, Australia
No solution here - but you are not alone. This seems to be a common
occurrence - works in SP1, but can't get the DHCP-assigned address in SP2.
I know on my computer that it is not the settings.
"Al Blake" <al@removethistext.blakes.net> wrote in message
news:%23MIhRG8sEHA.2596@TK2MSFTNGP15.phx.gbl...
> problems and given the number of other posts it seems SP2 is the issue:
> is quite happy and reports no errors. The machines sit there saying
> 'Acquiring network address' until eventually they time out.
> card.
> AP: Cisco 1200/350
> But of course no encryption on the WLAN is a non starter.
> all work fine.
> spent 2 days on this and got nowhere. Most frustrating is that when we
> tested this combination of hardware prior to the SP2 rollout it worked
> fine. In fact we have 2 of the 62 machines in the combinations that *CAN*
> connect to the WLAN after Sp2....which is even more frustrating......and
> if we re-image a machine that cant connect down to SP1...it immediately
> Regards
Al,
Your excitement is understandable, but could you calm down and
give us some essential details.
The Toshiba support site lists several "Satellite 1800" models,
which exactly is yours? Which exactly is it's wi-fi card model?
(Toshiba does not make the cards, so this might be OEM version
of somebody else's product).
Knowing this can help to find the real manufacturer of the card
and it's driver, and get the issue resolved faster.
Another question is, do you use the Windows Wireless configuration service
to configure the card, or some "utility" that came with the driver.
If the latter, have you tried to remove it and use the Wireless configuration
service of SP2 instead?
Regards,
Pavel
> AP: Cisco 1200/350
> all work fine.
> Regards
I have to agree that post SP2 the wireless connectivity of XP has
become useless unless you want an unsecure network. I had some
wireless clients working correctly for about a week then the following
occurred. Only thing added to OS was the updates. I have not went as
far to see if any of the updates have caused the problems. But to work
for a week then quit, leads me to suspect that is the problem. Here
are my problems below.
1 - IAS access was granted and IP address was issued with XP SP2 still
indicating it was acquiring network address. WAN and LAN was
accessible, but connection dropped out after a couple minutes.
2 - IAS access was granted and DHCP server broadcast ip address with
XP SP2 never ack-ing...timed out with 169.xxx.xxx.xxx address.
ipconfig release and renew with same results.
3 - Setting alternate config in network settings never worked
4 - IAS access granted, DHCP address accepted, XP SP2 reconnects every
4 seconds.
5 - with encryption off XP SP2 is happy and works fine.
6 - Modify registry not to auto config - set alternate config doesn't
work. Result - constantly acquiring network address.
7 - Any encryption, user password auth, certificates, in other words
anything to try and protect your network, XP SP2 fails.
With this pattern I can not get a grasp on what is causing the
problem. Again, I'll look at the updates from the initial install of
XP2.
Using linksys, buffalo, netgear, and orinco cards all have the same
results.
I have not found any solution other than to go back to SP1. I am
fortunate I never had put this into a production environment.
By the amount of posts on this subject, it looks like there are plenty
of people with this problem. I would be interested if anyone finds a
solution. I have been trying to correct this problem for over a
month.
End of venting,
Ron
On Sun, 17 Oct 2004 06:48:56 +1000, "Al Blake"
>AP: Cisco 1200/350
>all work fine.
>Regards
Possible breakthough today:
Turned *on* SSID broadcast on the access points and suddenly all the
machines that were giving problems can connect - with full authentication
and encryption. Strangely enough this works even when the 'broadcast' SSID
is *not* the SSID we end up connecting to...its early days yet but thetre
looks to be som wierd combination of card + SP2 + encryption here that
causes everything to fall in a hole when broadcast is not on.
Anyway - we use better security that just hiding the SSID
so Im gonna
leave it on for a week or two and see if its stable.
Al.
"Ron Lehner" <ron_lehner@hotmail.com> wrote in message
news
8e6n0d7pr3fdlnif39io7esbfbogtmvve@4ax.com...
> 4 seconds.
> XP2.
> results.
> month.
> End of venting,
> Ron
>>problems
>>is
>>'Acquiring
>>card.
>>AP: Cisco 1200/350
>>But
>>all work fine.
>>spent
>>this
>>we
>>WLAN
>>WLAN.
>>Regards
Hi Al,
Here is a repost of a message Carl DaVault sent out to
microsoft.public.windows.networking.wireless concerning using hidden SSIDs.
Chris Gual [MSFT]
This posting is provided "AS IS" with no warranties, and confers no rights.
---------- forwarded message ----------
First, make sure your AP and your wireless NIC's have the latest firmware
and drivers.
Next, unhide the SSID and make sure everything connects properly. Does
re-hiding the SSID make the problem re-appear?
If so, it might still be a driver issue.
A couple of things to note about "hidden" SSID's.
- If you are using them, then they are likely not hidden if a hacker wants
to see them.
- Windows tries hidden SSID's "last", so connecting to them may be slower
than to visible SSID's
- Some drivers have had problems connecting to hidden SSID's, so the
experience varies by NIC/driver
(what NIC/driver are you using?)
The way Windows handles hidden SSID's is this:
* It walks through your list of configured networks and tries to connect
to any ones that it can see.
* Then, if it didn't get connected or can't see any visible networks, it
tries each configured network anyway (in case it is hidden).
* It tries to connect by telling the NIC to use specific settings (SSID,
WEP, etc.) for the network.
(at this point, it is up to the NIC to do the actual
association, which is why I think it's a driver issue)
* Windows repeats this process until you are connected - you'll see
balloons letting you know when new networks are visible.
So if everything works with a visible, but not a hidden SSID, it might not
be a Windows problem. On the other hand, if you have a lot of networks
configured, windows is trying them one by one so it may just take a while to
connect - you can try moving the hidden network to the top of your list of
SSID's so it is tried first.
Hiding an SSID doesn't buy any security from hackers and you can use MAC
filtering to block regular people from connecting to your network even if it
is visible. I would recommend making your network visible since it will
improve your connection experience and doesn't hurt security. Even hidden
AP's and their clients are still blasting packets everywhere - it's just
that the beacon packets from the AP don't have an SSID in them. The AP will
still answer to the probe request for the SSID - the probes and responses
will also be visible to hackers.
- Carl
Standard Disclaimers -
and confers no rights. Please do not send e-mail directly
to this alias. This alias is for newsgroup purposes only.
news:uKG9vpPtEHA.2788@TK2MSFTNGP09.phx.gbl...
so Im gonna
> Al.
> news
>> 4 seconds.
>> XP2.
>> results.
>> month.
>> End of venting,
>> Ron
>>>problems
>>>is
>>>'Acquiring
>>>card.
>>>AP: Cisco 1200/350
>>>But
>>>all work fine.
>>>spent
>>>this
>>>we
>>>WLAN
>>>WLAN.
>>>to
>>>Regards
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
