Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Sony DSC-P100, odd mode change problem
Forum Computer Peripherals : Digital Cameras - Sony DSC-P100, odd mode change problem
Archived from groups: alt.comp.periphs.dcameras (More info?)
When I change modes when the camera is on, using the dial, the new mode
won't "take".
Here's an example. Most of the time I take distance shots, with the camera
on "scene" mode set for distance (the "mountains" icon). Then I come across
a flower, and set the mode dial on auto, and press the macro button on the
back (picture of flower). Though the flower icon appears on the LCD screen,
the camera will not focus near (it won't allow any half-way-button-push
focus), but acts as if it were still in distance focus mode. Any closeups
taken at this time will be blurry. If I turn the camera off, then power up,
it will now be in macro mode, and allow close focus.
Similarly, if I then put the camera on "scene mode" using the dial, turn off
the macro button, attempt a distance shot, the camera acts as if it is still
in auto mode, and will allow close focus -- unless I then turn the camera
off and power up again.
What gives? I thought I would find a clue in the manual, but I don't.
Sponsored Links
Some Sony's have an 'accessory lens' setting in the setup menus, that
locks the lens in a diffreenmt position for the use of add-on lenses.
Make sure that isn't on, if you have it.
Otherwise, see if you can find a 'hard reset' button to rest the
camera. The fact that you can't pre-focus on a half button press
indicates you have a serious problem...
Reply to Anonymous
There are 488 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
