G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
I posted a few days ago asking for help with my new pinnacle DV500 DVD capture
card. Since the majority said that it wasn't very good, I decided to return it.
I also discovered that I could use my camcorder as a analogue to digital
capture device.
However, despite buying new cables from Maplin, the signal is only in B/W. I
had it in colour with the Pinnacle device so I don't think that the VCR is the
problem. I've been reading about s-video and note that the luminance is
separate from the chrominance. What could be wrong??
I suspect that it's the cables because every posting on the MV500i is
favourable. They're brand new though. However, I could just be missing the
obvious. Copying my old VCRs to DVD has been one of my aims for several years
now and despite lots of hard-work (and money), I'm still struggling.
Thanks for any help!! I've just bought a whole new system for video-editing so
can replace any hardware if necessary. Should I get the canopus?? The camcorder
has hardly been used so it should be working perfectly. I just don't know!!!
Niall
capture device.
Niall
