Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
That will be the best and most troublefree solution...
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone -
http://www.microsoft.com/windowsxp/expertzone
On 25 Aug 2004 00:08:14 -0700, tonilounavarro@hotmail.com wrote:
>"Jeffrey Randow (MVP)" <jeffreyr-support@remotenetworktechnology.com> wrote in message news:<8ssni0tke0qcg9t4nt17uiii8ksojbr9ku@4ax.com>...
>> I actually haven't seen it work, but others reported that they can get
>> it to work.. I guess it fails over to the other gateway for the
>> private network after getting no response with the first gateway,
>> perhaps?
>> On Tue, 24 Aug 2004 08:49:33 -0400, "Lanwench [MVP - Exchange]"
>> <lanwench@heybuddy.donotsendme.unsolicitedmail.atyahoo.com> wrote:
>> >Jeffrey Randow (MVP) wrote:
>> >> Well, it definately won't work with the same IP address...
>> >> I have been "instructed" that it is possible to be in the same subnet,
>> >> though..
>> >I've never seen it work....the tunnel will appear to be established, but
>> >won't actually work. Same with any routed connection, no?
>> >> On Mon, 23 Aug 2004 08:51:30 -0400, "Lanwench [MVP - Exchange]"
>> >>> VPN won't work if you're using the same subnet in both places. Can
>> >>> you change the IP network on your home office?
>> >>>> Hello
>> >>>> I'm quite new with RD.
>> >>>> I'm connecting with RD via VPN to a host outside my office, using
>> >>>> Windows XP Pro. The host is Windows 2003 Server. I do not control
>> >>>> that host.
>> >>>> In the host network there is a machine with private IP 192.168.1.1.
>> >>>> My office has also a machine with the _same_ private IP,
>> >>>> 192.168.1.1.
>> >>>> Once connected to the host, when I ping 192.168.1.1 I get response
>> >>>> from my local computer; and I want to reach the remote computer with
>> >>>> that address.
>> >>>> Is this possible without reassignig IP addresses and the such?
>> >>>> Thanks,
>> >>>> Toni
>Well guys, thanks. It seems I'll have to change my local network...
>Toni
