G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hi all,
I hope this is the right forum for this problem I have. I am new to
DVD authoring and have limited tools. I have a Plextor external DVD
writer (PX-712UF) and a TRV27 DV camcorder using firewire for
downloading to the computer. The DVD authoring software I have is
ROXIO DVD creator 6.X Basic and it (to me) works pretty darned well.
The problem I have is a very tinny sound to the higher frequencies when
playing back from the DVD. I finally figured out that only footage
recorded @ 12bits would sound this way. Everything I taped @ 16bit
sounds fine after being burned to DVD. Is there a way to somehow
convert the audio from these tapes to 16bit before burning to DVD?
Should I try different software? A different forum, perhaps? ;^)
Thanks a bunch,
Alex
Hi all,
Thanks a bunch,
Alex
