Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems setting up a remote desktop
Forum Windows XP : Windows XP General Discussion - Problems setting up a remote desktop
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have a PC hardwired to my router and then a Notebook that is wireless. When
I try to connect remotely to either one it says that the other does not have
remote desktop enabled. I know this is a very easy fix but where do I go to
enable remote desktop?
Erik
Sponsored Links
Control Panel, System, Remote.
> wireless. When I try to connect remotely to either one it says that
> the other does not have remote desktop enabled. I know this is a very
> easy fix but where do I go to enable remote desktop?
> Erik
Reply to Anonymous
I have the same problem except all my PC's are hardwired
to my switch. I am trying to remote desktop within my
LAN. I am not running a domain, and have ran the Network
Setup Wizard on all 3 XP machines and I am able to see
all computers in My Network Places from all 3 stations.
I can also \\computername\c$ into them.
There is only one machine that is not accepting a
connection. I have tried enabling, disabling, and re-
enabling the service through ControlPanel/System/Remote
but to no avail. This machine is running SP1. I was
able to enable the service on the other 2 machines
successfully. Any advice will be appreciated.
Thanks in advance.
Mike
>-----Original Message-----
other does not have
>Erik
Reply to Mike
There are 1175 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
