Archived from groups: rec.video.desktop (More info?)
Using DV footage from mini-dv cam through Pinnacle Moviebox to capture
mpeg2 then converting to avi with Procoder to finally edit in
Premier...having trouble with the interlacing...any motion on screen
gives me the horizontal lines...All software I used to playback
converted avi file gave same results...how do i fix this...what are the
best settings for my scenario...thanks
eh?
Use firewire to transfer the DV in it's native lossless DV/AVI format,
edit that. Interlacing exists in the DV and should be retained if the
final output is destined for DVD or back to DV-Tape for TV playback.
Don't have firewire? the cards are less than $15 now, you'll probably
pay more for the cable.
You'll want to remove interlacing (de-interlace) only if the
destination playback hardware is going to be your PC. (Eg, you want to
make some small MPEG files or DivX/AVI.
