G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hello,
I have an older DirecTV/TIVO system with only AV and sVideo outputs. I use
an ADSTech Instant DVD+DV to convert the SVideo signal to capture to my
notebook thru USB 2.0
Most of my captures are of sporting events. The problem I have is that the
video doesn't play smoothly during action sequences. It is like a double
image of the parts in motion (hands/ball, etc).
When I capture from my Digital 8 camcorder or VideoTape through the
camcorder, the motion is fine so that is why I suspect the ADS capture
device. (I can't run the tv signal through the camcorder, I get a copy
protect error).
I also capture at 9.0 mb/sec which is what the device recommends for DVD.
Any advice on if this can be fixed or a better capture device?
Thanks
Allen
Hello,
protect error).
Thanks
Allen
