Archived from groups: microsoft.public.pocketpc (More info?)
We have created a pocket pc application (.NET application) that gets the
data (dataset) from a webservice ( runs on a Windows 2000 server).
If we run the application on a wireless PDA, it takes about 7 seconds before
the PDA gets the dataset (a small dataset with one table and 20 records). We
are sure that the time isn't lost within the webservice because the data is
retrieved from the database (oracle database) witin the same second. Testing
the method of the webservice in internet explorer, we get the data within
the second. Note that If we run the pocketPC application on the emulator
(from the .NET studio), the data is returned in +/- 4 seconds.
Can someone give me a hint where the time is lost ? Is this the time needed
for serializing the dataset ?
How can I improve the performance ? Can some setting (IIS setting, security
setting) reduce the time ? Is the datset causing the delay?
> before
> records). We
> is
> Testing
> needed
> security
> Thanks in advance for any help
Frank,
My first thought is are you trying to get the data from a "Docked" Pocket
PC or one connected by Wifi, or?? The reason is passing data through
activesync will be slow.
You might also try the newsgroup microsoft.public.pocketpc.developer
