Kodak NIMH Battery
Forum Computer Peripherals : Digital Cameras - Kodak NIMH Battery
Archived from groups: alt.comp.periphs.dcameras (More info?)
Hello everybody,
Just wondering if anybody has tried pulling apart the Kodak KAA2HR battery
pack and replacing the batteries with longer lasting and more powerful
batteries like energiser 2300mah. This would enable them to be charged in
the camera dock. If the energiser batteries are put in the camera on their
own you have to charge them externally with a separate charger. Is it safe
to do this? I am using the original camera dock and don't want to damage it
or the camera.
Thanks for any advice.
Dean
Sponsored Links
On Mon, 16 May 2005 12:54:59 +1000, "Dean Zito"
[snip]
A theorial possibility is the pastic tab on the back of the battery
pack triggers a switch inside the camera's battery compartment. If
you can insert a dummy piece to activate the switch while higher
capacity NiMH's are inserted, they would get recharged in a dock.
just make sure you don't try this with disposable AA's as it may
destroy the camera.
When you hear the toilet flush, and hear the words "uh oh", it's already
too late. - by anonymous Mother in Austin, TX
To reply, replace digi.mon with phreaker.net
Reply to Anonymous
"Dean Zito" <dzito@optusnet.com.au> wrote in message
news:42880b83$0$4655$afc38c87@news.optusnet.com.au...
> Hello everybody,
> it
> or the camera.
> Dean
>former post on fuji batteries from critcher looks like same problem
"just bought this camera and also the picture cradle, which states that you
can only charge the nh-10 battery and not any other batteries that you may
use in the camera, anybody know why this is so. I would have thought that if
the camera was using two separate Ni-MH batteries instead of the twinned
NH-10 then it would charge ok, any ideas anyone."
Reply to Anonymous
You have to understand that these are proprietary batteries we're taking
about.
That is, made for Kodak Camera's only,
In that respect, you have to consider this when making the purchase.
In any case, when choosing a new Camera, one should only consider a
Camera
that uses the newer type Li-Ion. With this battery it is no contest with
any other battery.
My Kodak Camera uses this type, and I can tell you they seem to last
forever.
As with all batteries of course, you should have a spare...
"critcher" <dennisgange@gothere.uk.com> wrote in message
news:1116254896.9390b8e8e137378a85024b8a37fa0a0b@teranews...
>> Hello everybody,
>> battery
>> their
>> safe
>> it
>> or the camera.
>> Dean
> you
> if
Reply to Anonymous
critcher says
the ni-mh batteries are very good and give a very long usage time.
"Yoonome" <Yoonome@Yoonowhere.com> wrote in message
news:Q3Nie.1408443$8l.1129846@pd7tw1no...
> taking about.
> Camera
> with any other battery.
> forever.
>>> Hello everybody,
>>> battery
>>> in
>>> their
>>> safe
>>> it
>>> or the camera.
>>> Dean
>> you
>> may
>> if
Reply to Anonymous
Greetings Dean,
Actually, Kodak sells a high mAh battery pack, i.e. 2100. They is not 2300
but do a very nice job. As to using non Kodak batteries in your camera,
please be aware that the packs that we sell are configured to work with
Kodak Docks and Printer Docks so they will charge while in the camera and
on the dock<s> It is a very nice system. You can use individual batteries
as well, but will have to charge them in their own devices or chargers.
Talk to you soon,
Ron Baird
Eastman Kodak Company
> Hello everybody,
it
> or the camera.
> Dean
Reply to Anonymous
Greetings Dean,
The Kodak EasyShare System incorporates a sensor in the camera that starts
the charging process. Without throwing that switch charging does not occur.
The switch feature is in the band that ties the two batteries together. If
you remove it or do not use this special feature charging will not occur.
You would have to use an external charger (wall charger) etc. Non-Kodak
rechargeable batteries will power the camera but not be charged in the
camera.
Talk to you soon.
Ron Baird
> > Hello everybody,
battery
in
their
safe
> > it
> > or the camera.
> > Dean
you
if
Reply to Anonymous
Critcher... You ain't seen nothing yet, till you try the Li-Ion
news:1116526147.162098bddd5a1cc34e8b2cc83f42ac94@teranews...
> critcher says
>> taking about.
>> Camera
>> forever.
>>>> Hello everybody,
>>>> battery
>>>> in
>>>> their
>>>> safe
>>>> damage it
>>>> or the camera.
>>>> Dean
>>> you
>>> may
>>> that if
Reply to Anonymous
Tom's Hardware > Forum > Computer Peripherals > Digital Cameras > Kodak NIMH Battery
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
