Archived from groups: rec.video.desktop (More info?)
Another stupid question.
I have downloaded the trial version of Vegas Studio 4 and am quite
impressed with its features.
My specific problem is a halo appearance around an actor that was
overlayed on a background using the chroma-key effect.
It would be ok for a home movie but I need to do it a bit better.
If this was a paint application I would create a mask - shrink it a
little and apply to get a nice crisp edge.
Any suggestions ?
Also the specs for the app indicate it only does 16 bit color. I am
used to dealing with 24 or 32 bit color. The test files I have produced
look fine on the computer monitor. Can anyone clarify this ?
<marks542004@yahoo.com> wrote in message
news:1104454066.466553.78430@z14g2000cwz.googlegroups.com...
DV is very difficult for chroma keying because of the heavy compression.
If you with a less than perfect image, it will never look good. This is one
area where Betacam is clearly superior to DV.
> Any suggestions ?
Thanks for the comment.
To clarify I am working with an mpeg file 320 x 240 in size.
This is being done for a website and client wanted it sized up for a
DVD sales promotion.
I have requested the camera tapes so it can be recaptured at full
resolution.
I had hoped there might be an edge filter or something to clean it up a
little.
It is also a dark green dress on a green screen background that looks
like it was wadded up in a cupboard for a few years.
I never had to deal with chroma key work before. I could do it by
extracting every frame, creating masks and reassembling them but life
is way to short.
news:1104457409.087263.6400@z14g2000cwz.googlegroups.com...
> resolution.
> little.
> is way to short.
Whoa, that's even worse than trying to pull a matte from DV.
Aftereffects has a choke that allows shrinking or stretching
a matte, it also has animated vector masks that can be used
to do the frame by frame thing. I know what you mean though,
I had to remove the color from 2 boys walking down the street.
You would think you could set some key frames and then just
let Aftereffects tween the rest, but no, I wound up tweaking the
mask for nearly every frame.
Does it have to get blown up to full frame? Perhaps it could be
in a mortise with accompanying text.
Pulling a clean matte with a badly wrinkled background would
be pretty much impossible. How about a plan B.
I converted the source mpeg to an uncompressed avi.
Then bringing it in to Vegas 4 and using chroma key has given me a
better result.
I think I can now get a satisfactory result for the web image (using a
brighter background than planned) and will simply not do a DVD unless
I can get the actual camera tape recaptured.
I am really impressed with Vegas 4 after having used Movie Maker . I
would love extra video tracks but just not in the budget for now.
> better result.
Huh ? Vegas 4 has unlimited tracks. Newer version 5 just adds 3D track
compositing.
For your keying needs, know that you can use more than one instance of the
chroma key filter/fx.
track
> compositing.
of the
> Craig H.
Sorry, my mistake
when I refer to Vegas 4.0 that I downloaded a trial version of I meant
Vegas Movie Studio 4.0 (retail about $99)
Since I was considering Pinnacle Studio 9 av/dv package I have decided
to buy the Vegas Movie Studio 4 and plan on upgrading to Vegas 5 a
little later.
Using an AVI file for the chroma key made a big difference to the
output. I was a little concerned at converting formats but the final
clip looks good.
news:1104531593.847209.129050@c13g2000cwb.googlegroups.com...
> Sorry, my mistake
> little later.
> clip looks good.
Congratulations,
