Remote Tab not on System Control Panel
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I installed XP cleanly from a CD. Then I did the windows update and it
prompted me to go directly to SP2 without installing SP1. I though sure, it
would pick-up all that I needed. Now when I go to the System Control Panel,
the Remote tab is not present. How do I enable the Remote tab? Do I need to
install additional software? I tried going to the Add/Remove Windows
Components and there was no option for Remote Desktop.
Please help,
smanders
8 answers Last reply
More about remote system control panel
  1. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    In message <70B0B533-5401-4335-B286-C27237DA4AE4@microsoft.com>,
    it
    to
    > Please help,
    > smanders
    Is this an XP Pro machine? If its an XP Home machine then the Remote Desktop
    tab will not be available.
    Al Jarvi (MS-MVP Windows Networking)
    Posted with Ink Spot (for PocketPC) from DejaVu Software, Inc.
    Usenet wherever you are - http://www.dejavusoftware.com/
  2. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    The CD was a Pro Version and if I go to the General tab under the System
    Properties says its:
    Microsoft Windows XP
    Professional
    Version 2002
    Service Pack 2
    But no Remote Tab.
    Thanks,
    smanders
    > it
    > to
    > > Please help,
    > > smanders
  3. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Try reregistering it using the command line that follows...
    regsvr32 remotepg.dll
    Otherwise do a repair install of Windows XP.
    http://michaelstevenstech.com/XPrepairinstall.htm
    NOTE THE WARNINGS ON THE REFERENCED PAGE!!!!
    Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
    The MS-MVP Program - http://mvp.support.microsoft.com
    This posting is provided "AS IS" with no warranties, and confers no rights...
    "smanders" <smanders@discussions.microsoft.com> wrote in message
    news:4E4E061B-D48B-4BDD-AC27-EC69ADB0A347@microsoft.com...
    > Professional
    > Version 2002
    > Service Pack 2
    > But no Remote Tab.
    > Thanks,
    > smanders
    >> it
    >> to
    >> > Please help,
    >> > smanders
  4. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I tried the "regsvr32 remotepg.dll" and it popped up a success window, but
    the tab was still not present. I am following the directions of the link
    provided. I wanted to mention though that the wpa.bak and the
    undo_guimode.txt were not present on my system. The only mentioned file that
    was present was the wpa.dbl. I did backed that up, and proceded with the
    install. I will post my results.
    Thanks again for your help,
    smanders
    > > Professional
    > > Version 2002
    > > Service Pack 2
    > > But no Remote Tab.
    > > Thanks,
    > > smanders
    > >> it
    > >> to
    > >> > Please help,
    > >> > smanders
  5. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Did you reboot after the regsvr32 command?
    Jeffrey Randow (Windows Networking MVP)
    jeffreyr-support@remotenetworktechnology.com
    Please post all responses to the newsgroups for the benefit
    of all USENET users. Messages sent via email may or may not
    be answered depending on time availability....
    Remote Networking Technology Support Site -
    http://www.remotenetworktechnology.com
    Windows Network Technology Community -
    http://www.microsoft.com/windowsserver2003/community/centers/networking/default.mspx
    Windows Home Networking Community -
    http://www.microsoft.com/windowsxp/expertzone/communities/wireless.mspx
    On Thu, 14 Oct 2004 11:19:03 -0700, "smanders"
    >smanders
    >> > Professional
    >> > Version 2002
    >> > Service Pack 2
    >> > But no Remote Tab.
    >> > Thanks,
    >> > smanders
    >> >> it
    >> >> to
    >> >> > Please help,
    >> >> > smanders
  6. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    I did not reboot, however RDP was not the only application that was not
    working properly. It was just the most critical one I needed. I went ahead
    and followed all the directions on the web site and everything worked
    beautifully. All my apps are still installed and I did the "admin" version
    of installing the service packs and I installed SP1 then SP2. All the
    expected applications were in place.
    Thanks so much for your help,
    smanders
    > >smanders
    > >> > Professional
    > >> > Version 2002
    > >> > Service Pack 2
    > >> > But no Remote Tab.
    > >> > Thanks,
    > >> > smanders
    > >> >> it
    > >> >> to
    > >> >> > Please help,
    > >> >> > smanders
  7. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Good result--thanks for persisting. It isn't necessary, with the Operating
    System service packs, to install the older ones--just installing SP2 would
    have been sufficient, fwiw.
    news:95944EB0-E24A-4721-959C-B3901098D312@microsoft.com...
    > ahead
    > version
    > smanders
    >> >but
    >> >link
    >> >that
    >> >the
    >> >smanders
    >> >> rights...
    >> >> > System
    >> >> > Professional
    >> >> > Version 2002
    >> >> > Service Pack 2
    >> >> > But no Remote Tab.
    >> >> > Thanks,
    >> >> > smanders
    >> >> >> > and it
    >> >> >> > though sure,
    >> >> >> it
    >> >> >> > Control Panel,
    >> >> >> > Do I need
    >> >> >> to
    >> >> >> > Windows
    >> >> >> > Please help,
    >> >> >> > smanders
    >> >> >> Remote Desktop
  8. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Glad you solved the problem.... :)
    On Fri, 15 Oct 2004 08:33:05 -0700, "smanders"
    >smanders
    >> >smanders
    >> >> > Professional
    >> >> > Version 2002
    >> >> > Service Pack 2
    >> >> > But no Remote Tab.
    >> >> > Thanks,
    >> >> > smanders
    >> >> >> it
    >> >> >> to
    >> >> >> > Please help,
    >> >> >> > smanders
Control Panel Windows XP
