Archived from groups: microsoft.public.windowsxp.work_remotely (
More info?)
Thanks for responding.
I'm using a Symantec Firewall/VPN 200R. I don't think they make or support
them anymore.
I was able to create a tunnel to another office the Firewall/VPN 200R and a
Symantec Firewall/VPN 100. Accomplishing this was actually pretty simple.
Setting up a remote connection has proven to be a little more complicated.
If the device is set to not return ping requests why can I ping it
internally? I'll look for that setting, but I did not notice it in the
software.
"Ed Dickinson" wrote:
> Guys,
> The Symantec device is probably set to not return ping request.
> Luis, are you able to create a tunnel?
> Which Symantec device are you using?
> "Robin Walker" wrote:
> > Luis F. Leon <LuisFLeon@discussions.microsoft.com> wrote:
> > > But the static IP I have with the ISP is not reachable
> > > through the browser from work or home.
> > > However, I can ping it from work but not from home.
> > If you cannot reach your work's WAN IP address from home, then there is no
> > way you can create a VPN connection into your work, and there is nothing we
> > can do to help you.
> > You need to discuss this problem with your ISP.
> > Maybe your ISP has put you behind a firewall, or behind a NAT router of its
> > own.
> > Perhaps if you told us what your work's WAN IP address is, then we could
> > check whether it is reachable from anywhere else.
> > Robin Walker
> > rdhw@cam.ac.uk
