XP Pro Dial Up Networking Problem
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I have a Windows XP workstation that I have configured to accept an incoming
dial up networking connection from my laptop.
About 75% of the time, my dial up connection is not working properly. I can
ping the Windows XP workstation fine, but I can't ping anything else on the
LAN connected to the workstation.
The other 25% of the time, my dial up connection works just fine.
Does anyone have any ideas what might be the problem?
Thanks,
Mike Schumann
2 answers Last reply
More about dial networking problem
  1. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Mike,
    You will have to be more specific about what programs/services you are
    using to connect and their settings before anyone can even come close to this
    one. However, if you have normal service at least some of the time then it
    suggests your modem is the problem - or the ehternet card in your workstation
    - or ...
    > dial up networking connection ...
    > Thanks,
    > Mike Schumann
  2. Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
    Problem Solved:
    The XP Pro workstation was assigning addresses to the incoming dial-up
    connection from my router's DHCP server. I changed the XP Pro configuration
    to assign addresses from a pool of addresses that did not conflict with the
    router's DHCP pool, and everything is now working fine.
    Mike Schumann
    "Mike Schumann" <mike-nospam@traditions-nospam.com> wrote in message
    news:OtbgnIqtEHA.3320@TK2MSFTNGP15.phx.gbl...
    >incoming dial up networking connection from my laptop.
    > can ping the Windows XP workstation fine, but I can't ping anything else
    > on the LAN connected to the workstation.
    > Thanks,
    > Mike Schumann
Workstations Networking Dial Up Connection Windows XP
