sometimes when im playing, the entire screen becomes unreadable with crazy colors, blurred walls and big triangular shapes. if i shut down and restart, its fine. just sucks when you're 10 ft from a save point and it happens. i have an ATI 9800 pro. (oh, and i dont do drugs)
Itchy and Scratchy #1325,Itchy plays Scratchy's skeleton like a xylophone; strikes the same rib twice but clearly 2 different notes sound. are we to believe that this is some sort of magic xylophone?
There was a known issue with Cat4.3, and their problem database says that it's solved in Catalyst4.4. However the description of the problem is different than what you describe.
Here is the <A HREF="http://www.ati.com/support/infobase/4465.html" target="_new">problem description</A> of the known issue in Catalyst4.3.
BigMac
<A HREF="http://www.p3int.com/product_center_NWO_The_Story.asp" target="_new">New World Order</A>
damn, mine were 3.8. i updated to 4.4 and i'll let you know!!! thanks!!
Slow the ram or gpu down on your overclocked video card... that was my problem and my solution... if you are not overclocking, ya, try the other drivers...
<font color=red><b>The mind is in its own place, and in itself
Can make a Heav'n of Hell, a Hell of Heav'n.</b></font color=red>
John Milton, <i>Paradise Lost</i>, Book II
BTW, I went from 3.7 to 4.3 last night because I read 4.3 worked well with NWN, but now FarCry is, indeed, messed up... I want to bed before trying to get rid of the distortion by changing settings... but if it is a 4.3 problem, that is good to know...
I had this problem on my overclocked Geforce 4 Ti4200. Even when every other game was stable at 300/600 On FarCry I would get those graphical errors after about 30 minutes of playing. In the end I put the card back down to default speeds and it worked fine.
<A HREF="http://service.futuremark.com/compare?2k1=7454540" target="_new">Yay, I Finally broke the 12k barrier!!</A>
I had the *exact* same problem with my first R9700Pro in any 3D game (<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=381844#381844" target="_new">thread</A> ). Hercules RMAd the card and the replacement is fine - most likely thought for the cause from the posters here at Tom's was long term heat damage. Of course, if you're o/c then try it at default first.
I'm having a similar problem. Also, at the same time the screen freaks out, I hear high pitched, garbled sounds. I had the 4.5's installed, but after several occurrences of the above I switched back to the 4.3's. I guess I'll try the 3.9's again for the hell of it. I never had a problem on my nForce 2 machine. Any ideas would be appreciated.
specs.
Athlon 64 2800+
MSI K8T Neo FIS2R
Radeon 9800 AIW Pro
2x 512 Corsair XMS 3200LL
2x Hitachi 7K250 80gb as RAID 1
Audigy 2
etc.
