Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Wired vs WIRELESS with USB Card
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Which gives faster speed or is it the same? Is there a distance on either on
how far you FROM HOST COMPUER! go before you begin to loose signal?
Sponsored Links
I am not sure I totally under stand you question.
There is No USB Network, the typical Network is Ethernet based.
There is USB to Ethernet device that let you plug a Network connection to a
USB port but the cable connected to this device is regular CAT5e cable, and
a CAT5e can take you up to 100 meters.
USB Wireless means that the Wireless device is connected to a USB port, but
the Network connection is Wireless Ethernet.
When using USB 1.1. both devices (wired or wireless) would provide a
theoretical Network "Speed" of about 11Mb/sec.
When Using USB 2.0 Devices with a USB capable computer the Wired device
provide the usual wired capacity of the Network.
A special Wireless USB2.0 device (very few are available) with USB2.0 port
would provide 11Mb/sec for 802.11b and 54Mb/Sec. with 802.11g.
The distance of the Wireless is similar to what ever typical Wireless might
yield (Info in the middle of this page:
http://www.ezlan.net/Wireless_Hardware.html ).
If you want to connect only two computers via the USB ports you need to use
a special device (see Option 3 in this page:
http://www.ezlan.net/direct.html ) using this device limits you to 15'.
Jack (MVP-Networking).
"Dave" <Dave@discussions.microsoft.com> wrote in message
news:FBE42773-41FD-4AF4-AA5E-135001199BB1@microsoft.com...
on
Reply to Jack
Hi
Basic Wired Network with the right hardware has no distance limitations (one
single wire can go up to 328') at a theoretical "Speed" of 100Mb/sec.
Wireless is a different story (makes very little difference if the card it
is USB or other type).
More info about "Speed" and distance here:
on
Reply to Jack
There are 603 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
