Premiere Pro Capture Problem
Archived from groups: rec.video.desktop (More info?)
I had Premiere Pro installed on an Intel box that
I borrowed from a friend, worked great. I bought
an AMD XP 64 bit system and installed Premiere
Pro 1.5 on it and copied my old projects over and
they were fine. I then tried to do a capture with
the same firewire card that I used in the other PC,
with the same cable and the same camcoder and I
cannot capture. I get control over the camcorder,
but the video is blank in the capture window. The
audio and video play in the lcd on the camcorder,
like it did previously, but no video in Pro. I
see the frames count by in the capture window and
when I stop the recording I get a message that says
that it did not capture any frames. I installed
the most recent drivers for my ATI 9600 Pro vid card,
though I didn't think that that would make much of a
difference. I reinstalled Pro and even tried an
earlier version of the vid drivers, but no joy.
What should I try next?
Thanks,
fyb
This is my sig
10 answers Last reply
More about premiere capture problem
  1. Archived from groups: rec.video.desktop (More info?)
    Let's assume the camera is 100% functional and you have everything setup
    correctly in Premiere. Which you should double check
    Can any other app capture over FW? Moviemaker.. etc?
    Isolate the problem. It may not be Premiere.
    "Lord and Master" <fybar@babs.hammerdog.org> wrote in message
    news:slrnctv70g.1o9i.fybar@babs.hammerdog.org...
    > Thanks,
    > fyb
    > This is my sig
  2. Archived from groups: rec.video.desktop (More info?)
    "nap" <gospam@yourself.com> wrote in news:w3WDd.9499$5R.647
    @newssvr21.news.prodigy.com:
    Movie maker behaves the same way, so then it is not Premiere that is the
    problem. I pulled the firewire card from that pc and put it into another.
    I was then able to capture from movie maker from that PC. Funny, that in
    this second pc the preview didn't show up, so I thought it was going to
    fail, but it captured the video. So, this is a configuration or
    incompatablility on my new pc then.
    So, I disabled hardware acceleration and tried OpenGL then back to Direct
    3D, still no joy. Do you have any other suggestions of what to try next?
  3. Archived from groups: rec.video.desktop (More info?)
    "fybar" <fybar@no.spam.me.shaw.ca> wrote in message
    news:Xns91AEA2895CC2Ffybarnospammeshawca@24.70.95.211...
    I suppose I would try a different slot for that FW card in the original PC.
    Preview issues on the 2nd PC may be related to the video card in there.
    It is even possible that it may take another firewire card .... at least
    they are cheap.
    Once it is working with MM it will work with Premiere.
  4. Archived from groups: rec.video.desktop (More info?)
    news:qlzEd.9073$wZ2.3713@newssvr13.news.prodigy.com:
    >>> setup correctly in Premiere. Which you should double check
    >> the problem. I pulled the firewire card from that pc and put it into
    >> another. I was then able to capture from movie maker from that PC.
    >> Funny, that in this second pc the preview didn't show up, so I
    >> thought it was going to fail, but it captured the video. So, this is
    >> a configuration or incompatablility on my new pc then.
    >> Direct 3D, still no joy. Do you have any other suggestions of what
    >> to try next?
    > original PC. Preview issues on the 2nd PC may be related to the video
    > card in there.
    > least they are cheap.
    I tried a different slot before, thee total. I installed some other
    codecs at the urging of another enthusiast but still nothing. I am
    going to go get another firewire card and try that. I have a Radeon
    9600 Pro with the latest drivers, maybe try an earlier version?
    Thanks for the help.
    fyb
  5. Archived from groups: rec.video.desktop (More info?)
    Sure it's not the AV->DV setting in the camera? I'm pretty sure (with
    Canon ZRxx cameras at least) that if you have AV->DV enabled (to do
    analog->digital passthru) then capture behaves as you're describing -
    i.e. the camera control works but it doesn't accept data over firewire.
    Disable AV->DV and see if that helps.
  6. Archived from groups: rec.video.desktop (More info?)
    news:Xns91AFB34F9E78Cfybarnospammeshawca@24.70.95.211...
    >>> to try next?
    >> card in there.
    Probably has nothing to do with the Radeon.
    > fyb
  7. Archived from groups: rec.video.desktop (More info?)
    news:_XTEd.9398$wZ2.1649@newssvr13.news.prodigy.com:
    >>>> is the problem. I pulled the firewire card from that pc and put it
    >>>> into another. I was then able to capture from movie maker from that
    >>>> PC. Funny, that in this second pc the preview didn't show up, so I
    >>>> is a configuration or incompatablility on my new pc then.
    >>>> to try next?
    Yup, it was the firewire card. Pretty flakey that I could get it to
    work with the other systems, but not this one. I got a cheap LaCie card
    and it works in all of the systems. The card giving me grief is a
    Dynex.
    Thanks for the suggestions!
    fyb
  8. Archived from groups: rec.video.desktop (More info?)
    you're welcome.
    news:Xns91B09497FC23Cfybarnospammeshawca@24.70.95.211...
    >>>>> to try next?
    > Dynex.
    > fyb
  9. Archived from groups: rec.video.desktop (More info?)
    I have almost the same thing happening to me. I have 2 IEEE ports on my
    Vaio, a 6 pin in the rear and a 4 pin up front. My old camcorder works
    connected to either port. My new one works with the 4 pin to 4 pin cable on
    the front port, but works like yours (control but no video) using the 6 to 4
    pin cable from the rear. Not sure if it is the port, cable length, or cable
    quality. Can you borrow another cable? I just use the front port.
    Larry
    > Thanks,
    > fyb
    > This is my sig
  10. Archived from groups: rec.video.desktop (More info?)
    "Larry" <Sternig@ColdMail.com> wrote in
    news:uljGd.218927$T02.205764@twister.rdc-kc.rr.com:
    > my Vaio, a 6 pin in the rear and a 4 pin up front. My old camcorder
    > works connected to either port. My new one works with the 4 pin to 4
    > pin cable on the front port, but works like yours (control but no
    > video) using the 6 to 4 pin cable from the rear. Not sure if it is the
    > port, cable length, or cable quality. Can you borrow another cable? I
    I replaced the IEEE card and I am now capturing without any problems at
    all. Very frustrating considering that the original card worked in 50% of
    the pc's that I used. Next time I have some kind of difficulty with a new
    peripheral I will go straight to exchanging it for a new one. I wasted a
    week trying to get this POS working.
    Thanks for the reply.
    fyb
Tuner Cards Video Graphics
