Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Remote Desktop vs. Other products
Forum Windows XP : General Discussion Remote Desktop vs. Other products
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
The company where I work currently uses VPN and PCAnywhere for remote access.
I am looking into alternatives and have looked a bit at MS Remote Desktop
feature. So far the things I dislike are the inability to restart the host
machine remotely and I am not too sold on the security. I have also looked
into GoToMyPC by Citrix and it looks like a good secure program. Of course as
with everything, cost is a factor and in that arena Remote Desktop wins. Can
anyone offer me advice if they have used any of the products listed?
Thanks!
Reply to wendy
You could use either "tsshutdn" or "shutdown" from the command line on the remote PC. Go to
"Start -> Help and Support" and search on both to get the proper syntax. In addition, the user can
do a "Ctl - Alt - End" key sequence in the Remote Desktop area and bring up the remote PC "Task
Manager". Then go to "Shutdown" and select either "Turn Off" or "Restart".
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Wendy" <Wendy@discussions.microsoft.com> wrote in message
news:4867B4E4-8E2E-404F-ACA4-C1D680031F88@microsoft.com...
> Thanks!
Reply to Anonymous
- 0 +
Thank you for the advice, the tsshutdn works from the run line. If I use the
/reboot switch it will reboot. I wish there was an easier way for the end
user. If anyone knows of an easier way for the end-user please let me know.
Thanks!
> > Thanks!
Reply to wendy
I use a product called Beyond Remote, it can be found at
http://www.dataapples.com
Mike
access.
as
Can
> Thanks!
Reply to Anonymous
You might check out logmein.com.
> Thanks!
Reply to Anonymous
There are 2023 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 1 day ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
