G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hi everyone, I hope you can help me with this.
I'm converting DivX avi to DVD, and I'm getting the hang of Virtualdub,
avisynth and CCE. I came across DVD2SVCD and it makes setting up
parameters very easy, but I'm having a problem with aspect ratios and
borders. I selected the 4:3 no borders option, and Resize to 720X480.
However, on preview, the frame width appears shortened from the sides,
and when run, the AVIsynth*.avs file confirms that the resize is like
520X480 with added borders 90,0,90,0 (from memory...I'm at work...).
(perfect hands-off a/v sync, BTW, even with VBR MP3)
What am I doing wrong??
Also, do you have any educated opinions as to the output quality using
the DVD2SVCD/RoBa method vs. the longhand vdub/avisynth/cce method? My
eye is not yet experienced enough to see the small stuff that affects
quality.
Thanks!
Dok
quality.
Thanks!
Dok
